try to install popcorntime in kubuntu but get errors when i want to unzip the file
what can i do ?
What errors do you get?
Do you have unzip installed?
Did you try to redownload that zip file?
It would be helpful, if
- you provided the link from where you downloaded the zip-file.
- you told us which errors you got. “I get errors” is rather unspecific.
- you specified whether you used command-line
unzipor the gui toolark
Addendum:
I have no intentions of installing it, but on Kubuntu 20.10, I tried the instructions on
As specified in step 1, I downloaded the zip file via:
wget -c https://get.popcorntime.app/repo/build/Popcorn-Time-0.4.4-linux64.zip
and then executed
unzip Popcorn-Time-0.4.4-linux64.zip
which worked without any issues.
