abhishek
(Abhishek Prakash)
24 July 2023 12:19
1
If you are following the Bash Basics series on It’s FOSS, you can submit and discuss the answers to the exercise at the end of the chapter:
Fellow experienced members are encouraged to provide their feedback to new members.
Do note that there could be more than one answer to a given problem.
Mayor
(Mayor)
30 August 2023 15:39
2
#!/bin/bash
numbers=()
read -p "Enter 3 numbers: " num
IFS=' ' read -r -a numbers <<< "$num"
numbers_length=${#numbers[@]}
reverse_numbers=()
for (( i=$numbers_length-1; i>=0; i-- )); do
reverse_numbers+=("${numbers[i]}")
done
echo "Numbers in reverse order are: ${reverse_numbers[*]}"
abhishek
(Abhishek Prakash)
31 August 2023 04:35
3
I liked the use of IFS. I guess I deliberately omitted that from the tutorial.
Bao
(Bao)
21 January 2024 14:45
4
another way to only litmit within the scope of that article, please
I still barely understand $IFS - but it gets me every time when I try to use a 2D range of values in a “for loop” - so I then have to “IFS=$'\n” when it gets unhappy
$IFS has been tripping (sic) me up for years…
Mark_J
(Mark_J)
25 April 2024 08:04
6
My first script for #2 was
#!/bin/bash
echo “Number reversal Exercise”
read -p "enter first number: " num1
read -p "enter second number: " num2
read -p "enter third number: " num3
reverse_number=($num3 $num2 $num1)
echo “The reverse order of numbers entered is ${reverse_number[*]}”
And then I saw the expected output and changed it to
echo "Enter three numbers and press enter: "
read -p “–>” num1 num2 num3
reverse=($num3 $num2 $num1)
echo “The reverse order of numbers entered is ${reverse[*]}”
By the way, Thank you Abhishek Prakash for this tutorial, I am learning so much from this.
