My MX21.3"ahs" install has been happily driving my networked Brother MFC640CW printer since I first set it up 6 months ago. Suddenly, 2 weeks a go it stopped working.
CUPS accepts a print request, it appears in lpq -a, but nothing happens at the printer. It spools forever.
So I reinstalled the drivers ( they are 32 bit ) cleared the print queue, and still nothing happens when I do a print test or a job.
So I reread the driver install instructions very carefully and discover that the library package lib32stdc++6 must be present.
Checking with dpkg -l | grep lib32stdc reveals that it is not present.
So I install it apt-get install lib32stdc++6
test the printing again, and it works.
So the mystery is… how and why did the package lib32stdc++6 get deleted?
It must have been present up until 2 weeks ago, or the printer would never have worked.
I have done nothing other than routine apt-get-update and apt-get upgrade so why would they have removed it?
I think the answer might be that lib32stdc++6 is a dependency only for my printer drivers, and they are installed with dpkg -i not with apt-get install, so they dont really belong to the package system , and the system thinks that lib32stdc++6 is not required by any package, so it deletes it.
So the question is, how can I tell the apt system that package lib32stdc++6 is not to be deleted?
Maybe I could find out what library files it installs, and move them to /usr/local/lib out of control of the package system?
and now I have an even bigger mystery, because when I look at those files , none of them were updated today… ie my apt-get install lib32stdc++6 did nothing to any library file,… but it made the printer work?
Is it possible for a package to be installed, but not activated?
I wonder did the ldconfig at the end of the install do something?
A conflict means that 2 packages are trying to provide the same file.
So does that mean I should delete something… I have
ii libc6:amd64 2.31-13+deb11u6 amd64 GNU C Library: Shared libraries
ii libc6:i386 2.31-13+deb11u6 i386 GNU C Library: Shared libraries
ii libc6-dev:amd64 2.31-13+deb11u6 amd64 GNU C Library: Development Libraries and Header Files
ii libc6-i386 2.31-13+deb11u6 amd64 GNU C Library: 32-bit shared libraries for AMD64
in addition to lib32stdc++6:amd64
That seems a tad excessive. What, if anything should I delete?
