Printer not recognised on Fedora 42!
Good morniing. Since installing fedora 42 printers are no longer recognised. I dual boot with Linux Mint, and there is no problem with the latter, but I simply can’t get printers to show up on Fedora. It is a Brother printer that has worked well in the past.
Ironically, I changed to Fedora from Mint a couple of years ago when I was also having printer problems. I got so frustrated that I decided to try several other types of Linux and use the first that would recognise a printer. Fedora won, so it is odd that I am having so much difficulty now.
Most Brother printers require drivers for Linux
Have you been into CUPS and attempted to configure the printer? It should ask you to choose a driver and you will then find out if Fedora has the required driver. I not you can download the driver from Brother and install it.
Fedora 42 recognized my HP printer automatically and picked up my Canon printer when I ran the rpm file that I downloaded from Canon. I did have to change the paper size from A4 to Letter for the Canon, but everything is humming along nicely now.
thank you for the replies. In fact, Brother does not require drivers, and I have used it ‘driverless’ for some time. Giving in to my frustration, I removed Linux Mint and have only fedora. It now automatically recognises the printer (as well as another I use) but when I go to print, it doesn’t show up in the printer list.
Which brother printer are you using ?
Normally just plugging in to the linux box the printers are seen and installed automatically as you discovered in Linux mint
I found i needed a restart afterwards for it to appear on the list, even though it printed immediately
Brother do offer drivers
Select your country or region and then printer
Last time I distrohopped - I sat on Fedora (39 or 40 or something?) for about 6 weeks - but that whole “RPMFusion” repo started giving me the irrits (irritation)… Don’t remember now (it was over 2 years ago) how well printing worked… Or even if I tried printing from Fedora…
So - I’ve been mostly on Pop!_OS on my desktop machine (Ryzen 7) and my Linux laptop (ThinkPad E495 with Ryzen 5) - and my printer is a Brother (MFC circa 2015)… It just works… I don’t have to do anything… Even though it’s an MFC - I only use it as printer from Linux… I use the MFC features via FTP to my NAS…
I do support some “legacy” Brother MFC devices for one of my customers, through CUPS - Brother only supplies and distributes 32 bit (i386) drivers for RPM based distros… The CUPS servers I support are running Oracle Linux 7 - and when I have to patch them - I have to temporarily disable i386 support - then - re-enable the 32 bit libraries - it’s a PITA…
So your drivers must be present in the distro.
My Brother MFC is an earlier model… I always have to install drivers.
If @ljohn has a new Brother printer, it is most likely driverless
My understanding is that with driverless printing the printer supplies a driver ( ie a PPD file) to Linux, so it is not really driverless, the printer supplies its own driver.
Not sure what year driverless printing arrived… I guess around 2020
If @ljohn has a driverless printer, and it does not work, that is a distro fault… report the bug .
A brief update. I really prefer Fedora in most respects to Linux Mint. However I have been defeated on this occasion despite all my efforts. I started with a clean slate and downloaded Fedora 42 on its own, but no printers were recognised, as they have been in the past. So I then installed Linux Mint 22.1 over Fedora, and the printers simply showed up automatically which is what used to happen with fedora.
You need to do some investigating. If you keep switching distros you will never find out what the fault is.
I just installed Fedora 42. It immediately found and installed my HP 4520. It found my Canon 4450 and asked for a driver. I pulled the file from Canon.com, selected the 64-bit rpm file, and installed it using Discover. Both printers are functioning normally; elapsed time under 10 minutes.
