Proxmox helper scripts
this might be neat, going to have to play around with this.
you’ll notice PVE and PBS scripts in there … those are great for setting your repositories up correctly and killing the “nag” subscription message that pops up on login.
you can hide the “nag” at login if you edit proxmoxlib.js file. There’s checked_command -line, where you add orig_cmd like this:
checked_command: function(orig_cmd) {
orig_cmd();
return;
Need to check your link! I’m just learning the Proxmox at the moment with a dual boot computer but I’m going to get a dedicated computer for Proxmox soon.
btw, Proxmox seems to have released an update that makes it so you can’t create large VMs with legacy BIOS anymore, you have to use UEFI. Just thought I’d share and save someone the hour or so I spent trying to figure out why I couldn’t create a 5tb VM the other day. lol
