Question about Snap desktop launchers
I am trying to put a launcher on my desktop for a snap package. I am sure I have done this before - the launchers were located at /var/lib/snapd/desktop/applications. I used to be able to browse to this location using nautilus but in Ubuntu 24.10 this does not seem to be possible.
It is not a problematic issue, I can launch the package in other ways, but I’m curious to find out why this has changed.
Copilot says this will work. It looks correct to me. Hopefully it works for you.
How to create a custom .desktop file. Here’s a step-by-step guide:
  1. First, create a new .desktop file in your local applications directory:
touch ~/.local/share/applications/your-app-name.desktop
  1. Open the file with your preferred text editor. Here’s a basic template:
[Desktop Entry]
Version=1.0
Name=Your App Name
Comment=Brief description of your app
Exec=snap run your-snap-package-name
Icon=/path/to/icon.png
Terminal=false
Type=Application
Categories=Utility;
Key fields to modify:
  • Name: The name that will appear under the icon
  • Comment: A brief description (optional)
  • Exec: The command to launch your snap app (use snap run package-name)
  • Icon: Path to the icon file (you can often find the icon in /snap/package-name/current/)
  • Categories: The menu categories where the app should appear
  1. Make the file executable:
chmod +x ~/.local/share/applications/your-app-name.desktop
Thanks for the response. I agree it looks as if it will work.
I suddenly had a thought myself and downloaded a different file manager (Nemo). This gives a “File System” option which enables me to browse to the required folder and copy the required launcher file to my desktop and it is a simple matter to make the file executable.
