Hi all, ![]()
after purchasing the 4G-stick Huawei E3372h-320 I found on
a link to a “user´s guide” for the stick. It´s
https://m.media-amazon.com/images/I/81RIP6vKO9S.pdf .
Here I found an interesting remark:
Disconnecting from a Network
Remove the Idea 4G netsetter from the computer.
Note:
If you do not need to connect to a network, it is recommended that you remove the Idea
4G netsetter from your computer to eliminate unwanted data traffic.
That made me wonder: How exactly do you do that? Unfortunately they didn´t elaborate on that. ![]()
I mean: surely I´m not supposed to shutdown/poweroff the computer in order to remove the stick.
So on a running system I think first of all I disconnect the stick from the internet by using the web-browser (“http://192.168.8.1” is the page for doing that).
The stick uses the HiLink mode, so that´s the only way of doing it I suppose.
Then I disconnect my LAN connection (as the stick created the LAN-interface “enx001e101f0000” on my system).
Now the stick definitively is disconnected from the internet but the LED is still blinking blue.
Referring to the user´s guide:
Blue, blinking once every 2s: The Idea 4G netsetter is registering with a 3G/3G+
network.
I´d say that´s as far as I can get. ![]()
May I remove the stick now?
As opposed to USB memory sticks there´s no way to “eject” it.
Many thanks in advance for your opinions on the matter.
Many greetings.
Rosika ![]()
