Hi all, ![]()
IΒ΄ve no idea whether the hdparm command is the correct topic here. So IΒ΄ll give it a shot.
Usually, when I boot up my system (Linux Lite 6.2) and I get past the login screen the first thing I do is open a terminal and issue the command:
set serial 57584C314135364855375855; and echo (lsblk -o name,serial | grep $serial | awk '{print $1}'); and sleep 2; and sudo hdparm -B /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and sleep 2; and sudo hdparm -B 254 /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and sudo hdparm -B /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and sleep 3; and sudo smartctl -A -d sat /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and echo $status .
(fish-syntax: β; andβ is the same as β&&β in bash)
This command provides an output like this:
/dev/sdb:
APM_level = 128
/dev/sdb:
setting Advanced Power Management level to 0xfe (254)
SG_IO: bad/missing sense data, sb[]: f0 00 01 00 50 40 fe 0a 00 00 00 00 00 1d 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
APM_level = 254
/dev/sdb:
APM_level = 254
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.0-76-generic] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
SMART Attributes Data Structure revision number: 16
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 126 108 021 Pre-fail Always - 4691
4 Start_Stop_Count 0x0032 097 097 000 Old_age Always - 3320
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 085 085 000 Old_age Always - 11588
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2305
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 163
193 Load_Cycle_Count 0x0032 178 178 000 Old_age Always - 66066
194 Temperature_Celsius 0x0022 111 104 000 Old_age Always - 36
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0
0
What is does is: it shows the current APM_level settings for my (external) HDD (128), sets it to 254 and in addition to that shows the HDDΒ΄s health status.
As I said: normally thatΒ΄s the first thing I do after login. And it worked every time without fail. I.e.: it worked immediately.
Today, however, at some point during the execution of the various commands it seems to have failed. As this is a multi-command expression I donΒ΄t know at which point. ![]()
I tried it right after the failure for the second time and again it failed. ![]()
I tried it a third time and it suddenly it was executed in a pefect way, as always. ![]()
Hmm, ![]()
IΒ΄ve never seen this behaviour before, so I shut down the system and performed a fresh (cold) startβ¦
β¦ with the same result. Only the third attempt was successful.
Once again I shut down the system and once again I started afresh. This time the very first attempt of the command sequence was successful, like it used
to be. ![]()
The only difference between the first two (failed) attempts and the last one was:
After the first and the second boot I issued the htop command before executing my βspecialβ command.
My third try was thus that I omitted βhtopβ and issued my command first. Now it worked immendiately.
IΒ΄m not saying that issuing the htop command first was the cause, I was just pointing out the circumstances.
I also took a look at the log files with lnav, but couldnΒ΄t see anything pointing towards any problems regarding the matter.
Does anyone have a clue what might have been going on ![]()
Thanks a lot in advance.
Many greetings
Rosika ![]()
