Why does it exist?
Is there anything in it?
Is anything mounted to it?
Dont be phased by ln it is the most counter-intuitive command in linux. I have used it for over 40 years and still have to look up the man page every time I use it.
Why does it exist?
Well, it´s the third partition of HDD.
Yes, all my personal data.
Hmm, I still cannot seem to comprehend the syntax.
In the ubuntuusers.de wiki they give the following example for a symbolic link (here):
In the following example, a link on the desktop (Verknüpfung_mit_Tagesplaner) will be created. It points to a file named haupt.odt in the user’s home directory:
ln -s /home/BENUTZER/Dokumente/Tagesplaner/Aufgaben/haupt.odt /home/BENUTZER/Arbeitsfläche/Verknüpfung_mit_Tagesplaner
So don´t they have it the wrong way too?
So you have your third partition mounted to it… right?
You will have to unmount it first ie unmount /media/…
Then it will be just an empty mount point
Then it would be safe to remove it… ie rm /media/…
and replace it with a link to /data… ie ln -s /data /media/…
then you can mount /data in fstab
No, that is correct, the last one (…Tagesplaner ) is the linkname
I told you ln
was counterintuitive. Its maker must have been standing on his head.
Thanks, Neville, for your reply,
Yes, the 3rd partition /dev/sdb3
at present (I mounted it manually) looks like this:
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sdb1 23G 17G 5,1G 77% /
/dev/sdb2 35G 27G 6,1G 82% /home
/dev/sdb3 385G 167G 199G 46% /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1
I see. At least I hope so…
Thanks for your patience, Neville.
I´m glad I understood it correctly then.
Yes, ln
seems very counterintuitive indeed. Normally I get things right but with this one I seem to have encountered some difficulties.
Thanks so much for your help, Neville.
Many greetings from Rosika
Yes,
ln
Glad you agree
most people think… " I want x to be a pointer to y"
but ln
does… " I have this thing called y , and I want to make a pointer to it, and call the pointer x"
Good luck if you decide to do the fstab bit
Thanks, Neville,
ln
That´s actually quite a good explanation. I´ll try to rember that in the future .
BTW: in the wake of our discussion I was looking at different ways of displaying mountpoints in the terminal.
I already knew mount
, df
and lsblk
but I also encountered findmnt
, which I have to admit was new to me.
Here I found a good article explaining it.
It´s a pretty lengthy but well-written article and I´m not through with it yet.
the default output from
findmnt
is tabulated and contains a tree showing the hierarchy of the mount points
I just had to familiarize myself with the nomenclature:
So “target” would seem to be the equivalent to “mount point”:
- Target: The location of the mount point in the file system
Thanks so much, Neville.
That is a good article
Did you notice all those mounts generated by snap?
Yes, Neville, now that you say it.
You´re right.
According to ubuntuusers :
Technically speaking, snaps are a single file that includes a squashFS file system, which in turn contains the program, the needed libraries, man-pages, etc. At the startup of the system, the current version of all active snaps is mounted, the mount point is the /snap/named structure with the /snap/NameDesSnaps/Version number.
(translation via “TranslateLocally for Firefox” add-on)
I guess that´s the reason for the abundance of snap mountpoints.
I´m glad I have no snaps whatsoever on my system (), so my entire setup looks less cluttered.
