@Rosika
I believe your mount point would be “mkdir -p /dev/sdb2 /mnt/media/rosika”
O.K., but the external HDD is not always /dev/sdb. …
OK, apologies for confusion
Do it like this
- Make a mount point eg
mkdir /data - Set its permissions. It is best owned by root
- in fstab put in a line like
UUID=f14a27c2-0b49-4607-94ea-2e56bbf76fe1 /data ext2 defaults 0 2
- boot and you should see /data in
df
I hope I am not spreading more confusion. When I see /media /… I think flash drives.
That only puts the mount point in /media instead of /run.
I then run chown 755 /media/xxxxx xxxxx
@Rosika
Probably because the device you are booting from is connected via usb?
Maybe @nevj can tell you how to keep a permanent mount with a usb device, I
know how to do it in Windows but haven’t tried it with Linux.
Thanks Neville
O.K., I see it now. This sounds good.
My getting confused is certainly not your fault.
On automount - How to make partitions mount at startup? - Ask Ubuntu I also found a GUI method by making use of the Disks programme. Apparently it will edit fstab for you…
I´m not quite sure about that. Therefore my asking here. …
Thanks a lot for your help.
Many greetings from Rosika
Yes, Daniel. That´s the case indeed.
Thanks and cheers from Rosika
Not happy with things being edited behind my back.
Yes, my thoughts as well. Therfore I´d like to do it personally and manually.
That happens whenever there is more than one disk… they are named in random order.
Thats why I use UUID.
It can cause enormous problems with installers… I almost installed Void on the wrong disk once.
Yes, I notice that on an almost daily basis.
I needed to modify my hdparm
command due to that as well:
set serial 57584C314135364855375855; and echo (lsblk -o name,serial | grep $serial | awk '{print $1}'); and sleep 2; and sudo hdparm -B /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and sleep 2; and sudo hdparm -B 254 /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and sudo hdparm -B /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and sleep 3; and sudo smartctl -A -d sat /dev/(lsblk -o name,serial | grep $serial | awk '{print $1}'); and echo $status
(fish-syntax)
Cheers from Rosika
Hi again,
I was just wondering:
@nevj suggested in post #43
… so the mount point for the device “f14a27c2-0b49-4607-94ea-2e56bbf76fe1” (UUID), which is my 3rd HDD partition), would be /data
then.
I understand that, but:
wouldn´t it also be possible to leave its mountpoint as it is right now when I mount it manually
df -h
Filesystem Size Used Avail Use% Mounted on
/dev/sdb3 385G 167G 199G 46% /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1
So to take up my question from post #34 again:
If that´s possible:
the correct entry in fstab
should be
UUID=f14a27c2-0b49-4607-94ea-2e56bbf76fe1 /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1 ext2 defaults 0 2
or am I completely mistaken
Yes, you can use any valid directory name for a mount point. The directory has to exist, before you try to mount anything to it. You should not mount anything to a directory that already has something mounted to it.
But why would you want to do that? Its a lot of typing to access it.
Some people like to put manual mounts inside /mnt and plugandplay mounts inside /media. It is just a convention.
Cheers
Hi Neville,
thanks for your reply.
Well, the reason for asking my question is the following:
I´ve written quite a few scripts in the past in which some programmes reference files which exist on the the 3rd partition.
If I´d follow your advice
the path would´ve been changed, right?
E.g: part of a certain script which would be affected:
cd /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1/DATEN-PARTITION/Dokumente/Zeitschriften_und_Bücher/Bücher_für_script-Referenz; firejail --net=none evince 10_easy_ways_to_restore_your_linux-system.pdf 2>/dev/null
So I guess I´d have to re-write all my scripts, which I´d like to avoid.
P.S.:
To be honest I have no problem whatsoever in manually mounting the 3rd HDD-partition after boot.
There´s an icon for it on the desktop. I just have to right-click and choose “mount”, that´s all…
I mean before having to re-write my scripts…
But it´s another case with my friend who has the exact same setup as me.
Root, home and 3rd partition, also Linux Lite (yet LL 6.4).
Also: no fstab
-entry for the 3rd partition per default.
However: whenever she wants to access her data on the 3rd partition (e.g.) by clicking on the left-side entry in thunar
she has to punch in her password; she has to be root to be allowed to access it.
This probably gets tedious on a daily basis…
Right. I see your issue. You could solve it with a symbolic link, or as you suggest, leave /media/… as the mount point.
O.K.,
in your post #38 you already suggested the use of a symbolic link:
Hmm, I´m not quite sure what you meant by that…
So /data
should be a symbolic link to /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1/
But where and when would I use the symbolic link?
You said: “don´t add it to fstab”.
Cheers from Rosika
I think you could do
ln -s /data /media/…
so /media/… becomes a pointer to /data
Then your scripts would follow the pointer and find /data
You only need to do the ln command once… the pointer will be there forever
O.K.,
let´s see if I get it right:
My command for creating the symbolic link would be:
ls -s /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1 /data
If that´s correct:
my fstab
-entry would be:
and my scripts are still catered for (due to the pointer).
Might all of that be correct
Cheers from Rosika
No you have it back to front
It is
ln target linkname
so when you issue the ln command, /data should exist, and /media/… should not exist… the ln command will make it
That is if fstab mounts the partition to /data, as you say.
It does not matter if you do the ln before you setup fstab or after.
I use links like that. I do it after I setup fstab.
Thanks, Neville. I seem to have messed up the syntax then.
Oh dear, then it´s not the right thing for me as /media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1
does exist.
Well, for my scenario is seems to be better to leave things as they are…
Thanks so much, Neville.
