ObiPanda
(ObiPanda)
1
Hi.
I haven't used linux much, or i'd probably know this answer already.
Can someone recommend a light linux distro for the following use case.
- To be Used in a VM
- It will run a few perl scripts and yt-dlp (python) via cron every so often.
- Bittorrent (prefer qbittorrent for network adapter binding)
- VPN (pia)
- A desktop, but nothing fancy.
- I also would like it in the Debian family, as I’m most familiar with it.
Thanks!
abhishek
(Abhishek Prakash)
2
Peppermint OS is a decent choice. You may also use something even lightweight like OpenBox on Debian itself.
4dandl4
(Daniel Phillips)
3
What is your host system, Windows or Linux?
Rosika
(Rosika Schreck)
4
Hi all,
Bodhi Linux is incredibly lightweight.
- A desktop, but nothing fancy: check
- in the Debian family: check
- To be Used in a VM :check # I´ve been using it in a VM for ages (1 GB of RAM assigned to it, runs perfectly)
Links:
Many greetings from Rosika
