`REmap` package and radar chart inside `echarts4r` package showing blank plot
Question
REmap package and radar chart inside echarts4r package showing blank plot.
Debugs
明白了Echarts.js和adminLTE.js都会使用$来作为一个调用的接口, 产生了冲突, 在JS层面产生了冲突, 所以不能同时使用
除了把它用htmlwidgets重写掉之外, 我想不出有什么解决的方法…
Citation: shinydashboard中如何展示REmap?DT::dataTableOutput一起用显示空白? #29
Check your canvas in the page. I suspect it’s just really huge and you need to scroll down a little to see it.
Citation: shiny htmlwidget renders blank
You can try using some jQuery directly in order to respond to the user clicking on the button. The onRender would be:
Citation: Shiny actionButton() output in onRender() function of htmlWidgets
原因总结 (transl: Reason)
  1. echarts路径错误 (transl: 1. echarts path error)
  2. 没有相关的json数据 (transl: 2. No relevant json data)
  3. 没有引入jQuery (transl: 3. doesn’t import jQuery)
Citation: 运行echarts的官方示例显示为空白的解决方法
Tried to raise an issue on GitHub 明白了Echarts.js和adminLTE.js都会使用$来作为一个调用的接口, 产生了冲突, 在JS层面产生了冲突, 所以不能同时使用 #428 and noticed that somebody knew js via 写了个htmlwidget R包:faq, somebody shade me a light?
