Remove Plata theme
I installed Plata theme based on this guide
I don’t like it when I tried. Can someone give me the command(s) to remove it please.
Just switch back to the theme you prefer.
Looks like this is for Gnome. Which distro are you running?
sudo apt remove (or purge) then remove the ppa:
I switched the theme, But I want to remove it from Ubuntu 18.04. Thanks.
