Hi all, ![]()
this is a follow-up on the topic of meld discussed here: Comparing files and folders with `meld` .
As I like to run as many programmes as possible within the firejail sandbox I tried running meld this way as well.
However it turned out that firejail hardcodes some paths as inaccessable by default for security reasons. ![]()
See discussion here.
So I wrote a script to circumvent this difficulty. ChatGPT has been of tremendous help, I have to admit. ![]()
The script aims to compare two files but without accessing the original ones.
If any of the files are edited you can still decide afterwards whether or not to exchange them for the original ones. That was my intention.
The script meld_compare.sh basically does the following:
Ask for the paths of the two files to be compared
Copy the files into a dedicated work directory. We can create a directory in /tmp or another suitable location.
Run
meldwithinfirejailto compare the two files. -
Ask whether to keep or delete the copied files after youβre done.
Handle any necessary sudo privileges for copying files that require them.
For anyone interested hereΒ΄s the script:
File: meld_compare.sh
ββββββββΌβββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
1 β #!/bin/bash
2 β
3 β # script for executing meld: copying two files, comparing them and ask if the copied ones should be deleted or kept
4 β # with kind help of ChatGPT
5 β # Wed 28.8.2024
6 β
7 β # Define the work directory
8 β WORK_DIR="/media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1/DATEN-PARTITION/Dokumente/ErgΓ€nzungen_zu_Programmen/zu_meld/fΓΌr_meld_script_copied_files"
9 β
10 β # Create the work directory if it doesn't exist
11 β mkdir -p "$WORK_DIR"
12 β
13 β # Ask for the paths of the two files to compare
14 β echo "Please enter the path for the first file:"
15 β read -r FILE1
16 β echo "Please enter the path for the second file:"
17 β read -r FILE2
18 β
19 β # Check if the files exist
20 β if [[ ! -f "$FILE1" || ! -f "$FILE2" ]]; then
21 β echo "One or both of the files do not exist. Please check the paths."
22 β exit 1
23 β fi
24 β
25 β # Determine if sudo is needed for copying the files
26 β NEED_SUDO=0
27 β if [[ ! -w "$WORK_DIR" || ! -r "$FILE1" || ! -r "$FILE2" ]]; then
28 β NEED_SUDO=1
29 β fi
30 β
31 β # Copy the files to the work directory
32 β if [[ $NEED_SUDO -eq 1 ]]; then
33 β sudo cp "$FILE1" "$WORK_DIR/"
34 β sudo cp "$FILE2" "$WORK_DIR/"
35 β else
36 β cp "$FILE1" "$WORK_DIR/"
37 β cp "$FILE2" "$WORK_DIR/"
38 β fi
39 β
40 β # Get the base names of the files for use in meld
41 β BASENAME1=$(basename "$FILE1")
42 β BASENAME2=$(basename "$FILE2")
43 β
44 β # Run meld within firejail
45 β firejail meld "$WORK_DIR/$BASENAME1" "$WORK_DIR/$BASENAME2"
46 β
47 β # Ask if the copied files should be kept
48 β echo "Do you want to keep the copied files in $WORK_DIR? (y/n)"
49 β read -r KEEP_FILES
50 β
51 β if [[ "$KEEP_FILES" == "n" || "$KEEP_FILES" == "N" ]]; then
52 β if [[ $NEED_SUDO -eq 1 ]]; then
53 β sudo rm "$WORK_DIR/$BASENAME1" "$WORK_DIR/$BASENAME2"
54 β else
55 β rm "$WORK_DIR/$BASENAME1" "$WORK_DIR/$BASENAME2"
56 β fi
57 β echo "Copied files have been deleted."
58 β else
59 β echo "Copied files have been kept in $WORK_DIR."
60 β fi
61 β
62 β # Terminate the script
63 β echo "Script finished."
64 β exit 0
The only path youΒ΄d have to modifiy to suit your needs is found in line 8:
For me the working directory is
WORK_DIR="/media/rosika/f14a27c2-0b49-4607-94ea-2e56bbf76fe1/DATEN-PARTITION/Dokumente/ErgΓ€nzungen_zu_Programmen/zu_meld/fΓΌr_meld_script_copied_files".
You can either choose e.g. /tmp/meld_work_dir or anything else that suits you better.
For surviving reboots (i.e. to retain the copied files) using /tmp is not advisable, of course.
Explanation:
- WORK_DIR: This is the temporary directory where the files will be copied. Itβs set to
/tmp/meld_work_dir, but you can change it if you prefer another location. - File existence check: Before copying, the script checks if the files exist.
- sudo check: The script checks if it has write permissions to the work directory and read permissions to the files. If not, it uses
sudoto copy the files. - firejail: The script runs
meldwithin thefirejailsandbox using themeld.profile. - File retention: After
meldis done, the script asks if you want to keep or delete the copied files. - Cleanup: Depending on your choice, the copied files are either kept or deleted, and then the script terminates.
Usage:
- Save the script to a file, e.g.,
meld_compare.sh. - Make it executable:
chmod +x meld_compare.sh. - Run the script:
./meld_compare.sh.
To be clear: The script primarily caters for the use case of running meld in firejail without any limitations.
For running it outside the sandbox this workaround is not needed.
Hope itΒ΄s some kind of help for any firejail advocates.
