Having sorted getting the Edit button back in Shutter I have now come up with another problem This editor is useful as I am in the habit of loading a template such as a birthday card, adding relevant text, saving under a new name and leaving the template for another occasion. Whilst adding the text is easy in Shutter I cannot find a way of preserving my template as there is no Save As option and Save will overwrite the template with the annotated card, Has anyone any idea how toget round this block: (Linux Mint 19.2)
There is no Save As option but there is an equivalent option known as Export to File.
You can access it from the top menu -> File -> Export to file.
The shortcut is Ctrl+Shift+E.
An obvious rewording of Save As with the opportunity to change the name. Thank you.
