Secure Linux Remote Access with AnyDesk (Unattended Mode)
Hi everyone,
This is a joint post by @nevj and @Rosika.
Neville (@nevj) and Rosika (@Rosika) recently experimented with secure unattended remote access using AnyDesk on Linux. We thought it might help others, so here’s a detailed guide based on our setup. Feedback welcome!
Note:
In this tutorial, we demonstrate the setup using Rosika accessing Neville’s remote machine as an example. However, the same method can easily be applied if you wish to configure unattended remote access to your own machine.
1. Why AnyDesk?
AnyDesk offers a simple, secure, and cross-platform solution for remote desktop access. Unlike SSH or VPN setups, AnyDesk does not require port forwarding or paid VPN services.
It also supports file transfer and graphical sessions out of the box.
In this tutorial, we’ll show how Neville (host in Australia) granted Rosika (client in Germany) secure unattended access to his Debian machine using AnyDesk (with some extra security considerations in mind).
2. Setup Overview
Host Machine (Remote — Neville’s Computer)
  • OS: Debian on bare metal
  • AnyDesk: Installed normally: anydesk.service is running
  • User Preparation:
    • A dedicated user account was created for remote access (e.g., rosika)
    • This user:
      • Has no sudo or root privileges
      • Belongs to minimal groups (only their own)
  • Anydesk Setup:
    • AnyDesk was enabled for Unattended Access.
      Go to Settings → Security and click the box´s ‘Enable Unattended Access’
  • Set a strong password
  • Neville provided the following credentials to Rosika:
    1. AnyDesk ID
    2. Unattended access password
    3. Username of the new account
    4. Password for that user account
  • (Optional): fail2ban was tested, but AnyDesk’s internal precautions appear sufficient.
Client Machine (Rosika’s Virtual Machine)
  • Host OS: Linux Lite
  • Guest OS (VM): Debian 11 “bullseye”
  • Virtualization: KVM/QEMU with virt-manager
  • Sandboxing:
    Started virt-manager inside Firejail:
    firejail virt-manager
    Within Debian VM: firejail anydesk
This ensures that the AnyDesk process running inside the Debian VM is sandboxed thus adding an extra layer of protection for the Linux Lite host and the Debian VM:
3. Logging In via Unattended Access
  • Launch AnyDesk inside the Debian VM.
  • Enter the remote AnyDesk ID.
  • Click Connect.
  • When prompted, enter the Unattended Access password.
  • You’re connected to Neville’s desktop session as a limited user.
4. File Transfer with AnyDesk
  • Click the “File Transfer” button in the AnyDesk toolbar.
  • A dual-pane file manager opens.
  • Drag and drop files between client and host.
  • File access is limited to the permissions of the remote (non-privileged) user.
5. Security Notes
  • No ssh ports or VPN needed. Anydesk has its own ports.
  • Remote user has no sudo/root privileges, unless granted.
  • Clipboard sharing disabled unless manually started (e.g. via spice-vdagent)
  • No shared folders between VM and host
  • Firejail + KVM VM = Strong isolation for the Linux Lite host
  • AnyDesk implements rate-limiting for failed login attempts
6. Why Not SSH or VPN?
While SSH is secure with key-based authentication, it requires:
  • Port forwarding
  • Dynamic DNS or static IP setup
  • Firewall configuration
  • Additional software and maintenance
With AnyDesk:
  • Remote GUI access is quick and beginner-friendly
  • No open ports = less exposure
  • Great for helping friends/family or remote troubleshooting
Conclusion
Remote access doesn’t have to be complex.
With AnyDesk and a few precautions (non-privileged users, sandboxing, and VM isolation), you can
enable safe, unattended Linux access — without exposing SSH or needing a commercial VPN.
Further Reading/Resources:
  1. Anydesk Official Documentation – Unattended Access:
    Set up Unattended Access
  2. Note on supported operating systems:
    Supported operating systems
  3. Firejail Documentation:
    Documentation | Firejail
  4. Virt-Manager User Guide (for managing KVM/QEMU VMs):
    https://virt-manager.org/
  5. Install and Use Qemu on Ubuntu:
    How to Install and Use Qemu on Ubuntu
Addendum
As far as file transfer is concerned you may have noticed in the respective screenshot that the file
für_sudo.txt (which I selected for the action) resides in the folder /home/rosika2/.anydesk/AnyDesk on my system.
I deliberately put it there, as my firejailed instance of anydesk restricts access to most folders.
So it´s a firejail thing and it has nothing to do with anydesk itself.
If you run anydesk the non-sandboxed way there´ll be no need to shuffle files around.
Important Note
Wayland vs Xorg Compatibility
At the time of writing, AnyDesk on Linux requires the host machine (the machine being remotely accessed) to use Xorg/X11 for incoming connections.
This is because:
  • Xorg allows AnyDesk to access the screen contents for remote control
  • Wayland, the newer display protocol, has stricter security and doesn’t yet allow screen sharing in the same way. In fact it does not have the networking capabilities of X11.
If your host system uses Xorg (which is the case for most current Debian, Linux Lite, and many other distros), AnyDesk works fine for remote access.
If the host switches to Wayland (more common on some newer distros), AnyDesk may not support incoming connections.
If you encounter problems in the future:
Check which display server you’re using run: echo $XDG_SESSION_TYPE.
It should return x11 for Xorg or wayland.
A lot of login screens allow you to select an Xorg session if needed.
Many greetings to everyone :heart: .
It was really good, right up to the bit where he stoll all your passwords, then accessed your bank !
Ha ha ha
Thanks for the guidance and working together so well
I personally never offer remote access to client machines to solve issues or problems, something I have been asked for but always say no.
What we intended to show was that one could use anydesk for remote unattended access to one’s own machine, in the same way that people use ssh or a vpn.
We just used my machine to test the idea. It worked well.
Nice guide!
Have you ever used Rustdesk? This also makes it easy to implement
No , we know Rustdesk exists and that it is open source. At the moment Anydesk has the reputation and @Rosika was familiar with it, so we used that.
Do you know if Rustdesk can cope with Wayland.?
gnulinux [in German] suggests that it does.
At least when using version 1.3.9 and if both machines use wayland.
The author stated:
Then I ran back and forth between my laptop in the living room and the desktop in the office room to make the connection between the two Wayland desktops.
This worked perfectly. RustDesk still declares Wayland support to be experimental, but it’s possible.
But:
according to him:
A log-in on an unattended device is not possible with RustDesk. It takes a person on the opposite side who allows remote maintenance, and even then a log-in is not possible.
That last statement still has to be verified.
The author is not 100% sure about that.
I applaud your efforts! Great to read about such a success :smiley:
What I like about Rustdesk, that it can work with a self-hosted server in the middle.
That option is attractive. Anydesk is a service, they provide their own server.
Exactly. I have installed my own Rustdesk server for about 100 clients (Windows 11). Runs very well
@kovacslt :
Hi László, :waving_hand:
Thank you very much. Also in the name of Neville (I hope I´m not too presumptuous in stating that. :wink: ).
True, but I was wondering…
On ubuntuusers they say about anydesk:
The connection is optionally via an AnyDesk server or as a direct connection.
Direct connection:
Instead of the AnyDesk address, enter the IP address of another computer:
anydesk --connect IP-ADRESS
… a TCP direct connection to the target computer will be established on port 7070. In the local network, the computer “name.local” can be entered (see also Avahi). In these cases, the authenticity of the other person can no longer be cryptographically verified via the AnyDesk server.
(Bold by me)
