Thanks for your input on this issue, which is now fixed @7:43 EST
We appreciate your enthusiasm, keep it up! That said, for the safety of our community, you’ve reached the maximum number of replies a new user can create on their first day. Please wait 7 hours and you’ll be able to create more replies.
The way I did it was: 1. right click on the main screen. 2. select Display settings from the drop down menu. 3. On the left hand menu select the Power setting. 4. Go down to the Power Saving Option. Click in the Screen Blank section, the next menu will give you the times, scroll to the bottom which is only 1 down, click on never, and that is it. Hope this helps.
Rodney Jackson.
