OK - I wrote a shell script this morning to run as a daily countdown… but the integer result I get is a negative value - i.e. a “signed integer”… I want an unsigned integer…
When I try to reformat it using printf "%u"
I get some weird number.
Background, U.S. band Tool are releasing their first new album in 13 years on 30/08/2019 - and I wanted to calculate the number of days between now - and then run a “countdown” of days: I’m a bit “okay” with the signed output - but I’d rather just a number, unsigned.
#!/usr/bin/env bash
# Calculate numdays till new Tool album :
FONT=big
END="190830"
while true
do
clear
export TD=$(date '+%y%m%d')
# echo $TD
# echo $(( ($(date --date=$TD +%s) - $(date --date="190830" +%s) )/(60*60*24) ))
TENKDAYS=`echo $(( ($(date --date=$TD +%s) - $(date --date="$END" +%s) )/(60*60*24) ))`
# TENKDAYS=$(($TENKDAYS + $TENKDAYS))
UNSIGN=$(printf "%u" $TENKDAYS)
echo " ------------------------------ "
echo ""
echo $TENKDAYS days till new tool album....
echo ""
echo " $TENKDAYS !!!" | figlet -f $FONT
echo ""
echo " ------------------------------"
sleep 60
done
e.g. today it returns “-51”… I’d rather just see “51”…
If I use $UNSIGN result from " - I get some huge long number (e.g. 18446744073709551566)…
update -
Note - I kinda resolved this by converting the signed int to a string - then used awk to remove the “-” if the value is less than zero… but I’d rather figure out how to convert the signed int to unsigned… -
update 2 -
Just typing this post I realised another possible solution - subtract -51 from 0 :
echo $((0 - -51))
