Followed recent downloading instructions for Signal using Terminal and Apt including pasting the instructions from the FOSS article into the Terminal. A check of /etc/apt/sources.list.d
showed it contained deb [arch=amd64] https://updates.signal.org/desktop/apt xenial main
. Then I executed ```
sudo apt update && sudo apt install signal-desktop
