Hi all,
I just installed Kubuntu 18.04.1 LTS (32 bit) on my Dell Inspiron 1300 laptop. No problems during installation. Only problem I have is there’s no Wireless/Wifi connection, only Wired. How do I enable wireless/wifi on Kubuntu 18.04.1 LTS so I can use my wireless/wifi connection? Any and All help appreciated.
Thanks,
John
scslomberg
(Stanley C Slomberg)
22 September 2018 21:09
2
I would install WICD. Sudo apt-get install WICD. I don’t know if this is what you want. I think there should be a link in Ubuntu for wifi
scslomberg
22 September 2018 21:25
3
Or you may need a Wi-Fi adapter.
Stanley
Type this into your konsole:
sudo lshw -C Network
Post the contents of what is posted here.
It will look something like this:
*-network
description: Ethernet interface
product: 88E8056 PCI-E Gigabit Ethernet Controller
vendor: Marvell Technology Group Ltd.
physical id: 0
bus info: pci@0000:04:00.0
logical name: enp4s0
version: 12
serial: 00:30:1b:bd:a7:e3
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
This is for my wired interface (Im on a pc) so we want to see your wireless interface.
Thanks for the replies and help. I guess I’m smarter than I thought when it came to this problem as I was able to figure it out on my own.
Pma38
(Pascal)
30 September 2018 04:21
6
Hi Jon,
on my Dell Latitude, this procedure runs :
connect the USB key live or insert live CD ROM
Search in this support:
libc-dev-bin_2.23-0ubuntu5_amd64.deb
install this package
llibc6-dev_2.23-0ubuntu5_amd64.deb
bcmwl-kernel-source_6.30.223.248 + BDCOM-0ubuntu8_amd64.deb
If you don’t have live usb key or live CD, connect your computer to ethernet (wire) to install same package as above.
I hope it will work for you.
Pascal.
