Whenever I try to install manjaro on my laptop by booting through the drive,it always gives error saying unknown filesystem and enters grub rescue mode.
I used Deepin Boot Maker to make the live USB.I tried this before too but not able to find the problem.
I Want to Clean Install my laptop only with manjaro.Give me Suggestions anyone.
Thanku!
Attaching the pic below
Just now i found out,Its the problem with deepin boot maker.I used Etcher.It worked Perfectly.Sorry for this post.Thank you!
Glad you managed to get around it
Try this terminal command to write the iso file to a USB stick.
sudo dd bs=1M if=manjaro-xfce-18.0.1-stablex86_64.iso of=/dev/sdx status=progress && sync
Change the x of /sdx to match the USB mount point at either /sdb or /sbc. Use “sudo parted” to confirm before writing.
If it is not Xfce, change according. Ditto with another OS ie Red Hat or Debian etc.
