On the left you will see 25 identical icons called <pre>connection<strong>Wired Connection 2 </strong>(802-3-ethernet) active </pre>
Wired Connection 2 is my DHCP link to modem and internet.
Before I get overrun with these icons, can anyone tell me
why are they there?
how can I remove them ( right click does not work, I get a networking menu)
I may have a similar thing going on with my work Windows laptop. A couple days a week I’ll go to Burger King and work for an hour or so while eating some breakfast. I use a MiFi device. Each time I connect it treats it like a new network connection and prompts to see if I want to allow external connections or not. It names them numerically WiFi-1, WiFi-2, etc. (not the exact name but it doesn’t matter).
Its an ethernet port connected permanantly to a Telco modem which has a fixed wireless link to a neaby tower. It is DHCP. It was setup as the primary network connection at install time.
I think those icons are generated by NetworkManager.
Every time I boot it makes another icon and they do not die when I shutdown.
I am beginning to think that the Xfce-session-saving may be saving them
Then after all the kills, the icons disappear
Then reboot, and what happens?.. I get one non-coloured icon which says Ethernet network connection "Wired Connection 2" active
and no coloured icons. There are no nm-tray processes and there is one nm-applet process.
So explain what was happening? There was a setting in the MX Session and Startup window which started an nm-tray process at system boot. This autostarted process was saved by my Xfce session saving settings. So next boot there was one saved icon and another new one started.
I dont need nm-tray, because NetworkManager starts nm-applet which produces the one non-coloured icon with exactly the same content as the multiple coloured nm-tray icons.
A case of too many cooks.
Final ultimate test. Reboot again. There is still only one icon.
Solved I hope
I guess not everyone uses Session Saving, so the problem would not be encountered. They might get 2 icons, one from nm-applet and one from nm-tray, but they would not multiply like rabbits.
Postscript:
I have discovered that nm-tray is a NetworkManager frontend written in Qt. What is it doing in MX/Xfce… that is GTK ?
