Running Mint19.1,MATE,64b. Will somebody please give me proper command to remove the noto directory(including its files), from /usr/share/fonts/truetype/noto ? Thank you.
1,5 second duckduckgo search…
Thank you for the reply, however, did nothing. Here is the command I used:
sudo rm -rf /usr/share/fonts/truetype/noto
I then used: sudo apt purge fonts-noto-* which worked. BTW-I had tried this command, prior to posting for assistance, but I did not include the * at end of command. Thanks again.
You could try this; To remove a directory use the rmdir
. If you have solved this previously could you please mark it as solved as I am not sure if you have done so or not. If you don’t know how to mark it as solved then ask and we’ll help you. Thank you
Marked solved-hopefully correctly.
are you saying that this solved the problem?
Yes. Did I not mark it solved correctly?
Thanks for doing so
You are very welcome!
