Static / noise / crackles on Audio CDsc burnt using Brasero
OK - I’ve done this previously running Pop!_OS 22.04 - and produced flawless audio CDs from WAV or FLAC…
But this is the 2nd time it’s happened to me - since I replaced Pop!_OS 22.04 with Ubuntu 24.04..
In both cases - I used Brasero - I couldn’t tell you the exact version on Pop!_OS because I’m no longer running it.
OK - so I burn an AUDIO CD from lossless format (either FLAC or WAV)… I then plonk the Audio CD in the stereo system in my Harley Davidson…
Previously - they were flawless (when burnt within Pop!_OS Brasero).
Now - they’re horrible and staticky… I’ve googled the symptom and not got any hits…
Any ideas?
Are the previous CD’s still flawless?
We have to rule out a problem in your Harley.
Given that, try another burner… I use Xfburn… because it comes with Xfce… not because I think it is superior.
You can do it by hand with genisoimage and wodim.
Check the burn speed is not too high.
That was my first thought- burning speed. Wonder if they both default to the same speed or do you think pop! might have been more conservative…
Do you still use CD thought that had gone away ?
Are you sure if the source, the quality of your cd and the final play system
Try head cleaners
Try to do the same to a USB key and see if the problem is the same
Edit: Just noticed @JoelA was quicker with the same idea.
I’m not familiar with brasero, but I has trubles with burnt CD’s when the writing speed was high, or the writable media was of poor quality.
I’d set the writing speed to the lowest available.
Maybe…
When I burnt an Audio CD on Friday - and it played all staticky - I ejected it and put the “store bought” Audio I had in it, back in - it played flawlessly…
Note : this bike is 18 years old (2007 FLHX) - damn - still seems kinda newish to me (I bought it new off the showroom floor) - but - it’s nearly vintage :smiley: - but it is all kinda “newfangled” compare to previous Harleys, e.g. twincam, fuel injected… But apart from the stereo - there’s no mod-cons… The 2008 model actually had cruise control, Brembo disk brakes and anti-lock…
I’ll try burning one more of the same thing and see if I can ramp down the burning speed… if that doesn’t fix it - I’ll give up… I’m not going to waste arm fulls of blank media just to troubleshoot something relatively minor - i.e. I can just play all the factory / store bought Audio CDs I already own… I don’t usually ride very far anyway…
But on Friday I wanted to hear a “new” band I’d only just gotten into (a band from New Zealand called BEASTWARS - but not “new” as in the album I tried to burn after buying it lossless [WAV] from Bandcamp was from 2011).
Did U try to reduce the speed of the burn. With older CD and roms you may have to slow down the job.
I was just going to say that till I read your post.
Tried it just now - burnt (instead of max speed - I chose the lowest “24x”) audio CD from WAV files (Bandcamp also lets you download in WAV format - it’s a freakin’ awesome choice!) - listening to track one on the burnt audio-CD now - sounds fine (on my computer) - i.e. no static or crackling.
Litmus test will be playing it in the CD player in my Harley Davidson… if it’s still horrible - I’ll give up and just use store-bought CDs (or audio CDs I burnt when I was still running Pop!_OS).
Update - never did get out on the Harley, got called into a massive “tech bridge” conference for a Solaris issue with a customer… 30+ people… Too many Chiefs, not enough Indians… or too many cooks… someone was pasting stuff in the chat they’d looked up with AI - yeah - this is SOLARIS UNIX not Linux! GRUB? No! SELINUX? No! :smiley:
Anyway - will have to wait till the weekend to see if I get same symptoms with an Audio CD burned at 24x speed (instead of max - other choices were 40 x and 32 x - no idea what speed “Max” is).
BTW - the album is brilliant - same band I mentioned at the top - Beastwars from New Zealand - new album came out last night - I’d pre-ordered it on digital download - bandcamp offer a plethora of choices :
“WAV” is 100% uncompressed CD-AUDIO quality…
But I usually download the FLAC - fully lossless audio codec (but it is still compressed)… Sometimes I also get the MP3 320 kbps for listening to on my phone - but - I can easily run a shell script to downsample FLAC to 320 kbps :
   1   │ #!/usr/bin/env  bash
   2   │ # grab the flac files in $PWD and convert to mp3 (320k)
   3   │ PROG=$(basename $0)
   4   │ IFS=$(echo -en "\n\b")
   5   │ ALBUM=$1
   6   │ # change "-mp3" at end of dir to "-flac"
   7   │ MP3ALB=$(echo $ALBUM |sed 's/-FLAC/-mp3/')
   8   │ # remove spaces from dirname :
   9   │ MP3ALB=$(echo $MP3ALB | sed 's/\ //g')
  10   │
  11   │ if [ $# -lt 1 ] ; then
  12   │     echo "need an argument"
  13   │     echo "... probably a folder with -FLAC in the end of the name..."
  14   │     echo "e.g. 1971 - If I Could Only Remember My Name-FLAC"
  15   │     echo "e.g.:"
  16   │     echo "          $PROG '1971 - If I Could Only Remember My Name-FLAC'"
  17   │     echo "... exiting now.... "
  18   │     exit 1
  19   │ fi
  20   │
  21   │ if [ ! -d $ALBUM ] ; then
  22   │     set -vx
  23   │     echo "$ALBUM folder doesn't exist..."
  24   │     echo "... so exiting doing nothing..."
  25   │     exit 1
  26   │ fi
  27   │
  28   │ check_it_2 () {
  29   │ if [ -d $MP3ALB ] ; then
  30   │     echo "$MP3ALB folder already exists..."
  31   │     echo "... so exiting doing nothing..."
  32   │     exit 1
  33   │ else
  34   │     mkdir $MP3ALB
  35   │     chmod 0750 $MP3ALB
  36   │ fi
  37   │ }
  38   │
  39   │ echo $MP3ALB
  40   │ echo "source : $ALBUM - destination $MP3ALB"
  41   │
  42   │ convert_it () {
  43   │ cd $ALBUM
  44   │ for f in $(ls *.flac)
  45   │ do
  46   │     # echo $f
  47   │     # echo "ffmpeg -i \"$f\" -ab 320k ../$MP3ALB/\"${f%.*}\".mp3"
  48   │     ffmpeg -i "$f" -ab 320k ../$MP3ALB/"${f%.*}".mp3
  49   │     # find any cover art :
  50   │     find . -maxdepth 1 -iname \*jp\*g -o -iname \*png -exec cp {} $MP3ALB/. \;
  51   │     # echo $MP3ALB/"${f%.*}".mp3
  52   │ done
  53   │ }
  54   │ # check_it_1
  55   │ check_it_2
  56   │ convert_it
  57   │ export NEWALBO=$MP3ALB
Can you give this CD player a clean?
Not really - don’t think it’s necessary… As mentioned several times - it doesn’t happen with bought audio CD albums - or - audio CDs I burned months ago…
Only audio CDs I’ve burned since I replaced Pop!_OS 22 with Ubuntu 24.04… but it’s consistent…
Still haven’t tried the CD I burnt on Friday (at the slowest speed Brasero offers) in the Harley…
Brasero was also the burning software I used on Pop!_OS…
Loud pipés saves lives …. So ride faster and harder you will not hear the noise
Only joking, take care and concentration on the road.
Bought CD’s are made by a different process… not burning.
but why the ones you burnt last year work is a mystery. ?
Were they burnt with the same CDR?
Yeah 100% the same hardware - except maybe a different NVMe SSD - but that shouldn’t make any difference… Same Mobo, same CPU, same DVD / CD / BlueRay burner device (it’s 13 years old - hardly ever use it - never did get BlueRay movies to play - software issue way back when I got it)…
Finally got around to testing the last CD I burned at 24x (instead of “max”) - and same symptom… In my Harley’s Harmon Kordon CD player… Plopped a store-bought CD back in - and it played okay…
I give up… I don’t ride that often… But it’s something that only started happening recently… CDs I burned earlier this year play just fine… Not a huge issue - but annoying…
It could be hardware maybe? I did unplug everything (SATA cables) when I replaced my CPU heatsink and fan… But that seems unlikely…
You win the award for ‘Unsolved mystery of the year’’
It is unfathomable.
