Su - postgres authentication failure
Hello,
I’m trying to install Bacula Community Edition on debian bullseye.
I’m following the instructions here
On page 9, in Final Configuration, there is the command:
su - postgres
In one of the earlier commands, a setup message / console application appeared, where I was prompted to enter a password (I had to enter that password twice, so I know what it is).
I assume that is the password that I should be using here, but it doesn’t work :frowning:
Would appreciate advice on how to work out what password I should be using here, or how to reset this password?
Thank you.
hmm…
Try to become root first:
sudo su
Now, you try and use the command:
su - postgres
It should not ask for password.
