The following error pops up when I type sudo apt update.
How can I resolve it.
Thanks in advance!!
Reading package lists... Done
E: The repository 'https://kernel.ubuntu.com/~kernel-ppa/mainline bionic Release' does not have a Release file.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Which version of Ubuntu are you using? It might be that your current version is incompatible with the version the repository is made for. For example, this repository is made for Ubuntu 18.04.
did you add that ppa to your system? i don’t have it in my /etc/apt/sources.list for ubuntu mate 18.04.3. if you did add it, where did you read that you should do so and can you share a link?
