I have been using Linux for awhile, but still have lots to learn.
Background - Using Linux Mint there is a app call “System Info” which gives a very brief information about your system.
The procedure - I also use Zorin. I could not find “System info”, so I went to the software library and installed “System Info”. From the install screen, I can also lunch the program.
The question - “System Info” is not listed in Zorin menu after the install. I assume there was a program installed, but what is it’s name? How can I find out?
Hi Howard,
I think getting an entry in the menu, or an icon, when a program is installed depends on whether the install puts a
programmename.desktop file in either
/usr/share/applications
or in
$HOME/Desktop.
or in
$HOME/.local/share/applications
and on what is in that file.
Its name will probably be obvious.
So see if you can find the .desktop file for your program
and have a look what is in that file.
Hi Howard (@easyt50),
I don’t know which program you installed in Zorin, but in Mint Cinnamon, “System Info” is not the real name of the command, this is just a “friendly name”.
The name of the command is cinnamon-settings info and cinnamon-settings is in /user/bin/cinnamon-settings, i.e., the complete command for run “System Info” is /usr/bin/cinnamon-settings info.
I’m trying to run Zorin on USB Flash, but I’m having problems booting from USB Flash at the moment. Please let me know which program you have installed and I’ll try to look up the name of the program.
how good to hear from you again. I hope you´re well.
I stumbled over xprop a long time ago. Don´t even know whether it was by accident or by actively searching for a way to find out the name of a running GUI.
I´ve been using it quite often in the past. I never would´ve thought it may be so useful .
whatis xprop
xprop (1) - property displayer for X
The man pages seem to be quite informative. There are even some examples there.
Hey Rosika,
That command seems pretty amazing and useful! I think its interesting how its a command on the CLI, but interacts with the GUI. I definitely will need to keep it in mind for the future.
I wonder what other interesting commands you know.
