Hi altogether,
I´m looking for a system-wide equalizer for Lubuntu 20.04.
When using bionic I was able to get qpaeq to work. At the time I followed the instructions given on
Install Pulseaudio With Built-In System-Wide Equalizer In Ubuntu ~ Web Upd8: Ubuntu / Linux blog .
I was tempted to do the same now, but learned on gnome - pulseaudio-equalizer is not working in Ubuntu 20.04 - Ask Ubuntu
that there might be issues when using focal.
Plus: When I type “qpaeq” in the terminal I get:
Der Befehl 'qpaeq' wurde nicht gefunden, kann aber installiert werden mit # command not found but can be installed with:
sudo apt install pulseaudio-equalizer
Now I´m unsure what to do.
Can anybody provide some good advice
Thanks so much in advance.
Many greetings.
Rosika
