Tardigrades Will Inherit The Earth (output in ffmpeg command)
True - fair dinkum mate :smiley: - tardigrades… Considering I was ALWAYS late for school (when I wasn’t wagging / playing hookie / truant) I can relate to tardigrades :smiley:
OK - I now have my script to convert a folder of FLAC files to a new folder of mp3 files… Slowly housekeeping all the duplicates (i.e. delete an mp3 album if I already have it in FLAC).
And - just decided to do some housekeeping on my digital movie “offsite backup for archival purpose only” :smiley: collection - I have dozens of them over 4 GB in filesize, some were close to 8 GB…
So - I’ve been using “ffmpeg” (I can’t imagine life without it - especially as my favourite movie player [mpv] use ffmpeg) to resample overly large video files using the libx265 codec (which is an upgrade of H.264 I believe) and changing the compression ratio (lossiness) - and watching the re-sampled video on my QHD 32" 165 Hz monitor about 2 feet away - having BOTH of them side-by-side - I can’t tell the difference - in some cases I’ve made a 10 fold saving! An 8 GB mkv is now between 8-900 MB and it looks just as good… For special stuff - I’m setting a slighly less lossy (-crf 24) value… I think the default is 23 - I might actually try 23 next time around and see if I still get any space savings…
Anyway - I got sick of searching back through my shell history - and I ended up writing a shell script to do it for me :
╭─x@titan ~
╰─➤  bat ~/bin/reducto.bash
       │ File: /home/x/bin/reducto.bash
   1   │ #!/usr/bin/env bash
   2   │ # Reduce a video file by #FACTOR
   3   │ PROG=$(basename $0)
   4   │ BNARY=ffmpeg
   5   │ echo "Usage : "
   6   │ echo -e "\t $PROG \$videofile \$factor"
   7   │ echo -e "\t\t where \$vidofile exists and : "
   8   │ echo -e "\t\t  $factor is some value between 20 (lowest) and 51 (highest) compression..."
   9   │ # defaults to using x265 format...
  10   │ if [ $# -lt 2 ] ; then
  11   │     echo "this $PROG expects two arguments..."
  12   │     exit 1
  13   │ fi
  14   │ VID="$1"
  15   │ FCT=$2
  16   │ if [ ! -f $VID ] ; then
  17   │     echo "$VID doesn't seem to exist...."
  18   │     exit 1
  19   │ fi
  20   │ if [[ "$FCT" =~ ^[0-9]+$ || "$FCT" =~ ^[-][0-9]+$  ]] ; then
  21   │     echo "looks like an integer then...."
  22   │ else
  23   │     echo "$FCT is NOT an integer..."
  24   │     exit 1
  25   │ fi
  26   │ if [ $FCT -gt 51 ] ; then
  27   │     echo "$FCT out of range - should be less than 52!"
  28   │     exit 1
  29   │ fi
  30   │ # EXT=$(echo $VID | awk '{print $NF}')
  31   │ # echo "${filename%.*}"
  32   │ NEWVID="${VID%.*}"
  33   │ echo Old : $VID
  34   │ echo New : $NEWVID
  35   │ echo "$BNARY -i $VID -vcodec libx265 -crf $FCT $NEWVID-x265-crf$FCT.mp4"
  36   │ $BNARY -i "$VID" -vcodec libx265 -crf $FCT "$NEWVID-x265-crf$FCT".mp4
AND I managed to write a shell script without any SWEARING in it too! I might change it a bit later to accept a 3rd argument, filetype by extension - i.e. mkv, mpg, avi as well as mp4…
That NEWVID="${VID%.*}" stuff is to lose the existing filename extension…
Anyway - about tardigrades - some of the output (several times - for each “stream”) from ffmpeg shows (that is quite possibly actually in the library - not the ffmpeg binary??? "mkvmerge or libx265) :
 Stream #0:0: Video: hevc (hev1 / 0x31766568), yuv420p(tv, bt709, progressive), 1280x688 [SAR 172:173 DAR 320:173], q=2-31, 23.98 fps, 24k tbn (default)
    Metadata:
      BPS-eng         : 3977147
      DURATION-eng    : 02:00:48.992000000
      NUMBER_OF_FRAMES-eng: 173802
      NUMBER_OF_BYTES-eng: 3603788774
      _STATISTICS_WRITING_APP-eng: mkvmerge v21.0.0 ('Tardigrades Will Inherit The Earth') 64-bit
      _STATISTICS_WRITING_DATE_UTC-eng: 2019-02-12 08:35:12
      _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
      encoder         : Lavc58.134.100 libx265
    Side data:
      cpb: bitrate max/min/avg: 0/0/0 buffer size: 0 vbv_delay: N/A
I love seeing humorous little “asides” in things like this!
Anyway - if I keep up this sort of house keeping the existing disks in my NAS should last at least another few years - I was under 1 TB free late last year - I now have 1.3 TB free!
I can only run one of these jobs at a time - tried to run two earlier today and slowed my desktop to a crawl :
bashtop output :
Post Script 1
I’m going to have to update my script to specify how many threads to use - just tried to do it now - and just one instance made my desktop crawl… Doesn’t really matter how long it takes - so long as it gets done… I can kick one off just before I go to bed for the night…
Post Script 2
Hmmm - just tried “ffmpeg -threads 4 ...” then “ffmpeg -threads 2 ...” - still crippled my desktop machine… didn’t seem to make a difference…
So - I reckon I might break out my old Phenom X6 system - install headless Ubuntu 24.04 server on that - and use that to re-sample video files…
In the first instance - Post Script 1 - I had to actually use TermUX on my phone to SSH and kill the ffmpeg job as I couldn’t get terminator or anything to respond…
Post Script 3
Hmmm - why use an old AMD Phenom II X6 - I have two MacBook M1? … Running it now with 2 threads and I can barely notice it impacting the Mac desktop environment… I might turn of the “-threads 2” setting completely and just let it kill the performance on the Mac… Probably get the script to have a 3rd argument - i.e. whether to use “threads” argument or not… and how many threads… The M1 has 8 cores…
By any chance… do you have hardware to assist h265 enciding? That would speed up the process a lot…
Hmmm - I wonder if I can use my GPU?
Radeon RX 6600/6600 XT/6600M (with 8 GB of DDR5 - not sure what AMD equivalent of CUDA is - so no idea how many GPU cores I have…
Plenty of other options to explore - but - I’m running it on all 8 threads on my work MacBook Pro M1 - and doesn’t seem to be flatlining like it does on Pop!_OS 22 with AMD Ryzen 7 CPU…
I hope I don’t have to do any compiling to get ffmpeg and libx265 to use my GPU as well as CPU… But looks like that is an option I can explore… I reckon would probably easier and more straightforward on NVidia with proprietary drivers to use CUDA cores for offloading onto…
Threads will not help if it is I/O bound.
Can you throttle the I/O?
Depends also on your ffmpeg build.
I get:
ffmpeg -encoders | grep hevc
ffmpeg version 5.1.5-0+deb12u1 Copyright (c) 2000-2024 the FFmpeg developers
  built with gcc 12 (Debian 12.2.0-14)
  configuration: --prefix=/usr --extra-version=0+deb12u1 --toolchain=hardened --libdir=/usr/lib/x86_64-linux-gnu --incdir=/usr/include/x86_64-linux-gnu --arch=amd64 --enable-gpl --disable-stripping --enable-gnutls --enable-ladspa --enable-libaom --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libcdio --enable-libcodec2 --enable-libdav1d --enable-libflite --enable-libfontconfig --enable-libfreetype --enable-libfribidi --enable-libglslang --enable-libgme --enable-libgsm --enable-libjack --enable-libmp3lame --enable-libmysofa --enable-libopenjpeg --enable-libopenmpt --enable-libopus --enable-libpulse --enable-librabbitmq --enable-librist --enable-librubberband --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libsrt --enable-libssh --enable-libsvtav1 --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvorbis --enable-libvpx --enable-libwebp --enable-libx265 --enable-libxml2 --enable-libxvid --enable-libzimg --enable-libzmq --enable-libzvbi --enable-lv2 --enable-omx --enable-openal --enable-opencl --enable-opengl --enable-sdl2 --disable-sndio --enable-libjxl --enable-pocketsphinx --enable-librsvg --enable-libmfx --enable-libdc1394 --enable-libdrm --enable-libiec61883 --enable-chromaprint --enable-frei0r --enable-libx264 --enable-libplacebo --enable-librav1e --enable-shared
  libavutil      57. 28.100 / 57. 28.100
  libavcodec     59. 37.100 / 59. 37.100
  libavformat    59. 27.100 / 59. 27.100
  libavdevice    59.  7.100 / 59.  7.100
  libavfilter     8. 44.100 /  8. 44.100
  libswscale      6.  7.100 /  6.  7.100
  libswresample   4.  7.100 /  4.  7.100
  libpostproc    56.  6.100 / 56.  6.100
 V....D libx265              libx265 H.265 / HEVC (codec hevc)
 V....D hevc_nvenc           NVIDIA NVENC hevc encoder (codec hevc)
 V..... hevc_qsv             HEVC (Intel Quick Sync Video acceleration) (codec hevc)
 V..... hevc_v4l2m2m         V4L2 mem2mem HEVC encoder wrapper (codec hevc)
 V....D hevc_vaapi           H.265/HEVC (VAAPI) (codec hevc
So I could use nvenc with nvidia (if I hadn’t discarded it :smiley: ), the quicksync with intel gpu, and VAAPI.
I use the intel quicksync nowadays for transcoding stuff, it’s lightning fast and good quality - requires non free va driver installed.
If I had only the Radeon, I’d try to go with the vaapi codec,
Cool - so it looks like I have a choice of hevc_vaapi on my AMD Linux systems - and probably “hevc_videotoolbox” on my M1 Macs (if I can ever get homebrew working again on my work MacBook - ffmpeg converted a video file for me last night - went to use it again this morning and nothing from homebrew is working [e.g. not even vi / vim]). I don’t know if using GPU on Ryzen with Vega (i.e. Radeon APU) is stealing threads from the CPU (i.e. robbing Peter to pay Paul) or not…
I’m going to make a copy of some smaller files somewhere and run a few benchmarks / test runs to get a feel for it…
I now have this in my script (if it gets a 3rd argument it assumes that’s the number of threads - if not the script defaults to 8) :
echo "$BNARY -threads $THRD -i $VID -vcodec libx265 -crf $FCT $NEWVID-x265-crf$FCT.mp4"
$BNARY -threads $THRD -i "$VID" -vcodec libx265 -crf $FCT "$NEWVID-x265-crf$FCT".mp4
If I try to have “-threads N” as a $VAR in that - it treats it as a double space and doesn’t proceed for some reason I can’t be arsed to figure out…
It would seem they can ‘freeze-dry’ themselves into a state or rest. Bacteria can do that, but I did not know any multicelled animal could do it.
The chemistry of life is fascinating… I did not think so when I almost failed my biochem exam.
Hmmm - maybe not such a good idea?
Trying it on my Pi5 right now - 4 arm64 cores and 8 GB RAM… No idea how long it will take…
Hmmm - a while I reckon :smiley: - a LONG while …
My Ryzen Pop! machine does about 68 frames per second…
both my M1 macbooks about avg between 20-40 fps…
The Pi 5? about 4.4 fps :smiley:
I don’t reckon the AMD Phenom II X6 would be that sluggish… So the arm64 cores in a Pi are still a far cry from the arm64 cores in Apple Silicon :smiley:
On Rpi I would probably try hevc_v4l2m2m.
So far never tried…
As for benchmark, intel quicksync encoding can do near 400 fps at full hd resolution on my side. It’s for h264 though, did not need h265 yet…
From what I’ve read - h265 gives better quality for less size…
How do you use both a GPU and a codec like libx264 at the same time on the same CLI?
I can’t figure that out… I reckon I’d get better throughput on the Macs if I used “videotoolbox” - but not sure how to use both that, and libx265 on the same command…
Yes, but there’s no free lunch. h265 requires much more computing power to encode :wink:
I have no idea…
When I try to use hevc_vaapi (instead of libx265) I get errors :
ffmpeg -threads 2 -i Alatriste-BRRIP-1080p-x264.mpv -vcodec hevc_vaapi -crf 24 Alatriste-BRRIP-1080p-x264-vaapi-crf24.mp4
Stream mapping:
  Stream #0:0 -> #0:0 (h264 (native) -> hevc (hevc_vaapi))
  Stream #0:1 -> #0:1 (aac (native) -> aac (native))
Press [q] to stop, [?] for help
Impossible to convert between the formats supported by the filter 'Parsed_null_0' and the filter 'auto_scaler_0'
Error reinitializing filters!
Failed to inject frame into filter network: Function not implemented
Error while processing the decoded data for stream #0:0
Conversion failed!
╭─x@titan ~/Videos/Movies/2006-Alatriste
╰─➤  ffmpeg -encoders |grep hevc        1 ↵
ffmpeg version 4.4.2-0ubuntu0.22.04.1 Copyright (c) 2000-2021 the FFmpeg developers
  built with gcc 11 (Ubuntu 11.2.0-19ubuntu1)
... SNIP ...
  libavutil      56. 70.100 / 56. 70.100
  libavcodec     58.134.100 / 58.134.100
  libavformat    58. 76.100 / 58. 76.100
  libavdevice    58. 13.100 / 58. 13.100
  libavfilter     7.110.100 /  7.110.100
  libswscale      5.  9.100 /  5.  9.100
  libswresample   3.  9.100 /  3.  9.100
  libpostproc    55.  9.100 / 55.  9.100
 V..... libx265              libx265 H.265 / HEVC (codec hevc)
 V..... nvenc_hevc           NVIDIA NVENC hevc encoder (codec hevc)
 V....D hevc_vaapi           H.265/HEVC (VAAPI) (codec hevc)
But this works :
ffmpeg -threads 2 -i Alatriste-BRRIP-1080p-x264.mpv -vcodec libx265 -crf 24 Alatriste-BRRIP-1080p-x264-x265-crf24.mp4
Reckon I’ll just keep plodding along using libx265… and paying for my lunch (which is usually free - cause I usually fast all day until dinner time - I’ve lost 10+ kgs in 18 months - as well giving up sugar in my coffee).
Post Script 1:
This worked :
ffmpeg -vaapi_device /dev/dri/renderD128 -threads 2 -i Alatriste-BRRIP-1080p-x264.mpv -c:v hevc_vaapi -vcodec libx265 -crf 24 Alatriste-BRRIP-1080p-x264-vaapi-crf24.mp4
(or it didn’t crash out anyway - or not yet)
Started of getting ~140 fps - but now dropped below 30…
Might do better if I didn’t limit threads to 2 maybe?
I updated my “reducto” shell script to use a python “wrapper” around ffmpeg…
“ffpb”
pip install --user ffpb
   4   │ BNARY=ffmpeg
   5   │ VID="$1"
   6   │ FCT=$2
   7   │ THRD="$3"
   8   │ echo $THRD
   9   │ echo "Usage : "
--- SNIP SNIP ---
  62   │ # echo "$BNARY -threads $THRD -i $VID -vcodec libx265 -crf $FCT $NEWVID-x265-crf$FCT.mp4"
  63   │ # $BNARY -threads $THRD -i "$VID" -vcodec libx265 -crf $FCT "$NEWVID-x265-crf$FCT".mp4
  64   │ BUNNERYTWO=ffpb
  65   │ echo "$BUNNERYTWO -threads $THRD -i $VID -vcodec libx265 -crf $FCT $NEWVID-x265-crf$FCT.mp4"
  66   │ $BUNNERYTWO -threads $THRD -i "$VID" -vcodec libx265 -crf $FCT "$NEWVID-x265-crf$FCT".mp4
All it (ffpb) does is wrap a progress indicator around ffmpeg - just what I needed - YAY!!! :smiley: It takes ALL the exact same arguments as ffmpg and runs ffmpg with those args…
Thread Argument = threads 2
ffpb -threads 2 -i Avatar-1080-BRRIP-3d-Half-SBS.x264.mp4 -vcodec libx265 -crf 28 Avatar-1080-BRRIP-3d-Half-SBS.x264-x265-crf28.mp4
Avatar-1080-BRRIP-3d-Half-SBS.x264.mp4:   6%|███▎  | 14688/232848 [05:28<1:04:22, 56.48 frames/s]
I’ve been unable to tell the difference with re-sampled output of mp4 or mkv files “reducted” per above when watching in mpv…
So if a job starts killing my CPU - I can see how close it is to finishing before I decide to kill it - or - go make a cup of coffee :smiley:
– edit –
I should really make BUNNERYTWO the full path to the python script… But /home/x/.local/bin is now in my $PATH in my ~/.zshrc …
I might try this again with 4 threads and compare…
– edit 2 –
By default - the first “user” on MacOS gets UID 501… On my Linux systems - my main user account - typically called “x” is UID 1000…
Boy - a fair amount of work on MacOS to do this - the (over NFS) permissions of my movie collection folders on my NAS are 755 - i.e. owner full (1000), group and other read or exec only… Last time I tried this on my MBP M1 - I had to change the folder to 775 (my default / main user on MacOS is GID 1000… Right now I’m trying to add a 2nd “shell only” user to my M1 MBP so I can get UID 1000 when access my NAS over NFS…
Hmmm - it might work over SMB though… Don’t lke using Samba if I can avoid it… Prefer NFS…
Reckon I’ll stick with Linux for the time being…
– EDIT 3 –
WTF? The above output ended up creating a 25% BIGGER FILE! WTF?
-rw-r--r-- 1 x family 2544679199 Jun 21  2021 Avatar-1080-BRRIP-3d-Half-SBS.x264.mp4
-rw-rw-r-- 1 x family 3108716488 Mar 18 12:20 Avatar-1080-BRRIP-3d-Half-SBS.x264-x265-crf28.mp4
Giving up for now… will try again later… Got issues with my PC - makes a hideous rattling when the CPU (or GPU) ramps up… I’ve pulled it out of its hutch and cleaned it up and reseated nearly everything… But still happens… PIECE of CRAP - next time round I might get a name brand “off the shelf” from the likes of Dell or whatever (this is one I built myself from components)…
Sound like a fan issue.?
100% - it’s the CPU fan…
Did some tests with with “coolercontrol” installed and watched what happened when I spun up a job to resample some video file to a more reasonable size…
Didn’t touch my GPU fans… So - I reckon it’s maybe the bearing in my STUPID (as in who even needs all that RGB bullshit?) AMD factory CPU fan…
So I ordered a Stealth Wraith cooler from Amazon - but that was last week and it hasn’t even shipped yet! WTF? I don’t even want a new heatsink (I HATE replacing heatsinks on modern CPU) - I just wanted a replacement stock fan - but - I want something quiet…
I may yet cancel it and see if I can get something locally - but my favourite local computer store only has like 30 versions of some 3rd party heatsink and cooler - and most of them are for AM5 CPU slot - I need AM4…
Turned out the noise was the power supply… Who’d a thunk?
Replaced the P/S with a “quiet” coolermaster ATX P/S and rattle noise gone…
In other news - “ffpb” seems to be broken on my Debian Trixie machine that runs JellyFin media server…
Updated (sudo apt upgrade) - and JellyFin uses a different ffmpeg binary than comes from the Debian Repos (still version 7)… It updated the Jellyfin ffmpeg…
Still no progress bar…
Rebooted…
ffpb does show a progress bar on my Ubuntu 24.04 desktop though…
I hate it when stuff that worked (ffpb was working yesterday on Debian) stops working… I’m back to using my Ubuntu desktop machine to transcode video files - because I want to see the progress bar when I’m running ffmpeg…
Just figured out how to use my AMD GPU for HW acceleration in ffmpeg…
-hwaccel_device "/dev/dri/card1"
But I think my Intel Arc A310 GPU does it better… But I won’t use that again until I can figure out why ffpb is silent (it doesn’t echo anything!)…
I cant find any ffpb?
There is ffprobe… is that it?
no - ffpb is a python front end to ffmpeg that shows a progress bar…
It takes ALL the exact same arguments as ffmpeg, and, passes them to ffmpeg… it’s a wrapper for ffmpeg…
I may try removing it and re-installing…
I installed it with pipx - the Python package manager…
I just re-installed it on Debian 13 - and still the same symptom… no output whatsoever… ffmpeg at least outputs stuff… It’s still doing the job - just not echoing anything - the whole point of ffpb is to echo something at least… it’s worthless otherwise…
OK - so I removed it completely… installed it via pipx (pipx install ./master.zip) and it’s working again on Debian… phew!
Holy c@rp !
I now have three versions of my script that runs ffpb to run an ffmpeg transcode…
On my Ryzen Desktop - I’m using h264 and hwaccel=/dev/dri/card1 (my Radeon GPU)
On my Intel i5 - I’m using h264 and hwaccel=/dev/dri/renderD129 (my Intel Arc GPU)
On my M1 Mac from 2020 - I’m not using “hw_accel” - I’m using “h264_video_toolbox” as Codec…
And the Mac is considerably faster than both! I’m kinda amazed…
The Intel GPU is circa 2024 (bought it in 2025)
The AMD Radeon GPU is circa 2022
The Mac is a 2020 device - purchased in 2021…
the proof of the pudding will be the end file size… running the exact same thing - i.e. h264 and a CRF (compression) of 27…
Hmmm - the Intel Arc GPU is considerable slower even than the AMD! WTF? I suspect maybe /dev/dri/renderD129 is now the i5 and not the Arc… The devices got flip-flopped, that’s so annoying!
Just double-checked… The Intel Arc A310 GPU is indeed renderD129…
╭─x@mimas ~
╰─➤  ls -al /dev/dri/by-path
total 0
drwxr-xr-x 2 root root 120 Feb 26 14:39 .
drwxr-xr-x 3 root root 140 Feb 26 14:39 ..
lrwxrwxrwx 1 root root   8 Feb 26 14:39 pci-0000:00:02.0-card -> ../card0
lrwxrwxrwx 1 root root  13 Feb 26 14:39 pci-0000:00:02.0-render -> ../renderD128
lrwxrwxrwx 1 root root   8 Feb 26 14:39 pci-0000:03:00.0-card -> ../card1
lrwxrwxrwx 1 root root  13 Feb 26 14:39 pci-0000:03:00.0-render -> ../renderD129
╭─x@mimas ~
╰─➤  lspci -s 0000:03:00
03:00.0 VGA compatible controller: Intel Corporation DG2 [Arc A310] (rev 05)
Bit disappointed - that’s slower than my older AMD Radeon… and way way way slower than my 2020 M1 MacBook Pro…
Never mind - the main reason I got it (Intel GPU) was the developers of JellyFin recommend Intel GPU over AMD, and recommended discrete Intel ARC GPU over integrated GPU on Intel…
Note - I’ll probably be using my Mac M1 in preference to the Ryzen desktop (with discrete AMD Radeon GPU), or the i5 headless debian system (with discrete Intel ARC GPU)… I just gotta figure out how to map my Mac UID (501) to my main UNIX ID “1000” (I use 1000 on Ubuntu and Debian and TrueNAS / FreeBSD)… Otherwise I’ll just have to make all my folders 100% group writeable… I don’t like doing that…
The final results :
methone (MacOS 15.6, ffmpeg 8.x, Apple M1) :
ffpb -threads 4 -i "Test003-methone.mp4" -map 0 -c:v copy -c:a ac3 -c:s copy -c:v h264_videotoolbox -crf 27 "Test003-methone-h264_videotoolbox-crf27".mkv
Test003-methone.mp4: 100%|████████████████████████████████████████████████████████| 191952/191952 [15:09<00:00, 211.00 frames/s]
titanii (Ubuntu 24.04, ffmpeg 6.x, Ryzen 7 Radeon RX 6600/6600 XT/6600M ):
ffpb -hwaccel vaapi -hwaccel_device "/dev/dri/card1" -threads 4 -i Test002-titanii.mp4 -map 0 -c:v copy -c:a ac3 -c:s copy -c:v h264 -crf 27 "Test002-titanii-h264-crf27".mkv
Test002-titanii.mp4: 100%|████████████████████████████████████████████| 191952/191952 [23:39<00:00, 135.27 frames/s
mimas (Debian 13, ffmpeg 7.x, i5 [gen10] Intel Arc GPU) :
ffpb -hwaccel vaapi -hwaccel_device "/dev/dri/renderD129" -threads 4 -i Test001-jellyroll.mp4 -map 0 -c:v copy -c:a ac3 -c:s copy -c:v h264 -crf 27 "Test001-jellyroll-h264-crf27".mkv
Test001-jellyroll.mp4: 100%|█████████████████████████████████████████████████████████████████████| 191952/191952 [34:08<00:00, 93.71 frames/s]
The Mac has 8 GB RAM, the Ryzen 64 GB, the i5 28 GB… The Arc A310 GPU has 6 GB DDR5, the Radeon RX6600 has 8 GB DDR5, the Mac just uses the system RAM…
Some of those differences maybe due to different ffmpeg versions… I did anecdotally witness that my Ryzen system with Pop!_OS 22.04 and ffmpeg 5, was slower than after I replaced Pop!_OS 22 with Ubuntu 24 (ffmpeg 6). But note - ffmpeg 6 is faster than ffmpeg 7 in above example…
Oh - and one other MAJOR thing to report - the one encoded on the Mac M1 is massively larger than the others! i.e. despite specify a CRF of 27 for all the jobs (compression level) - the video file generated on the Mac is 12 GB (from an original of 2.1 GB!).
So - I WON’T BE USING the Mac M1!!!
