Does anyone know of a terminal program that allows the user to save various commands in order to not have to re-key them all the time?
I find myself using a half dozen or more commands regularly and it would be nice if there was a saved list, maybe on a drop down menu, to allow selecting previously saved commands.
Thanks, Jim
Are you looking for a GUI or non-GUI program?
This is my favourite GUI Terminal. It can for example save commands, so you only need to click on the one you need.
GUI is always nice but I donât need anything fancy. Iâm just too old and lazy to remember and re-key commands like ârm -rf ~/.cache/thumbnails/*â and âsudo journalctl --vacuum-time=3dâ every couple of weeks. I looked up a website on installing deepin-terminal in linux mint but got this error:
sudo add-apt-repository ppa:noobslab/deepin-sc
Cannot add PPA: ââThis PPA does not support bionicââ.
Thanks Akito!
Jim
How about Cronjobs?
Thatâs a clever idea Akito but it looks to complicated for my simple mind. I envisioned a terminal very similar to the one that comes with Linux Mint but with an added feature of being able to save/edit some commands in a list so I could easily run them when I want.
Guess I can just keep the commands in a text file and copy/paste them into the terminal as needed.
Thanks again!
Jim
Just another suggestion:
How about adding âcommentsâ to your wanted commands?
rm -rf ~/.cache/thumbnails/* # Clear thumbnail cache
So you can easily search and select them with Ctrl+R
Not your wanted solution, but kind of a workaround⌠and kind of lazy ![]()
A text file is how I save my commands.
If you are only interested in half a dozen commands how about using up or down keys to search through your past. An easy solution if not many commands
Good idea Fast Edi! Thanks!
That works but I have so many entries in between the times that I use those half dozen.
If there was a way to display all of the saved, past commands and pick and chooseâŚ
Thanks ObillO!
Do you have a fixed list of commands you use or does the list of commands change often?
Can the âbookmarksâ tab in the terminal help, Iâve been trying and got a few commands that I can recall. this works for all i have stored, but i dont know if it will configure for a greater library!
I have a few that I use regularly and I add more as I learn them.
What about you? Do you use lots of commands? Are they easy to remember?
The terminal program that Iâm using doesnât seem to have a bookmarks tab.
Well, I have a list of over 200 aliases I use for the commands I use commonly. But for recurring operations it is really best to use cronjobs, as displayed earlier. It is not that hard to set up.
THANK YOU AKITO!!!
Iâm marking this SOLVED.
Although, after about 4 years using Linux, I consider myself quite the newbie - but, thoroughly in love with Linux. ALIASES are all new to me and I have some learning to do but this already seems to work just fine for what I want.
On another note, I FINALLY convinced my wife to give up on WIN 10 and converted her laptop to Linux Mint last week. I think that I have a new convert to the Linux family. ![]()
Again, thanks so much for your help!
Jim
I know this is solved - but this kinda looks like a use case for the âscriptâ commandâŚ
Itâs installed by default on Ubuntu, and I know it was âstockâ way back when in Solaris 7/8/9/10 etcâŚ
Just type âscript output.txtâ and it will plonk you into a âsubshellâ - everything you type gets recorded (and output too into âoutput.txtâ)⌠once youâre done, type âexitâ and youâll be back in your previous âshellâ. Everything you typed, and feedback/responses/output, will be in the file âoutput.txtââŚ
Thanks Daniel!
Iâll check that idea out too.
Jim
Just push up arrow key on your keyboard with Terminal open, to see the last command you used.
Thanks Mark! I appreciate the reply.
Jim
