The Gentoo Novice
@daniel.m.tripp
So, you have a Gentoo Root CLI?
run nano /etc/security/passwdqc.conf and change the enforce=everyone to users save and then run passwd root
I just use rt
Ttying to emerge vim?
run cd /etc/portage ls
and cd package.use ls
and post you results
gentoo-mungrel00 ~ # cd /etc/portage
gentoo-mungrel00 /etc/portage # ls
make.conf     package.accept_keywords  package.mask  profile     savedconfig
make.profile  package.license          package.use   repos.conf
gentoo-mungrel00 /etc/portage # cd package.use/
gentoo-mungrel00 /etc/portage/package.use # ls
00cpu-flags
OK now run cd package.use ls
run touch package.use and this should put a file in the package.use directory
verify with ls again
gentoo-mungrel00 /etc/portage/package.use # touch package.use
gentoo-mungrel00 /etc/portage/package.use # ls -al
total 12
drwxr-xr-x 2 root root 4096 Jun 18 11:42 .
drwxr-xr-x 9 root root 4096 Jun 17 06:45 ..
-rw-r--r-- 1 root root  104 Jun 17 05:37 00cpu-flags
-rw-r--r-- 1 root root    0 Jun 18 11:42 package.use
all I need is the package.use ls I do not need the ls -al
00cpu-flags  package.use
Ok!!! Now run emerge --ask --pretend app-editors/vim and the dependencies should show again
gentoo-mungrel00 ~ # emerge --ask --pretend app-editors/vim
These are the packages that would be merged, in order:
Calculating dependencies... done!
Dependency resolution took 2.31 s.
[nomerge       ] app-editors/vim-9.0.1503::gentoo  USE="X acl crypt gpm nls sound -cscope -debug -lua -minimal -perl -python -racket -ruby (-selinux) -tcl -terminal -vim-pager" LUA_SINGLE_TARGET="lua5-1 -lua5-3 -lua5-4 -luajit" PYTHON_SINGLE_TARGET="python3_11 -python3_10"
[ebuild  N     ]  app-vim/gentoo-syntax-10::gentoo  USE="-ignore-glep31" 21 KiB
[ebuild  N     ]   app-editors/vim-9.0.1503::gentoo  USE="X acl crypt gpm nls sound -cscope -debug -lua -minimal -perl -python -racket -ruby (-selinux) -tcl -terminal -vim-pager" LUA_SINGLE_TARGET="lua5-1 -lua5-3 -lua5-4 -luajit" PYTHON_SINGLE_TARGET="python3_11 -python3_10" 16,615 KiB
[nomerge       ]  media-libs/libcanberra-0.30-r7::gentoo  USE="alsa gnome gstreamer gtk3 pulseaudio sound udev -gtk2 -oss -tdb" ABI_X86="(64) -32 (-x32)"
[nomerge       ]   media-libs/libpulse-16.1-r2::gentoo  USE="X asyncns dbus glib gtk systemd -doc (-selinux) -test -valgrind" ABI_X86="(64) -32 (-x32)"
[ebuild  N     ]    media-sound/pulseaudio-daemon-16.1-r7::gentoo  USE="X alsa alsa-plugin asyncns bluetooth dbus gdbm glib gstreamer orc ssl systemd udev webrtc-aec -aptx (-elogind) -equalizer -fftw -jack -ldac -lirc -ofono-headset (-oss) (-selinux) -sox (-system-wide) -tcpd -test -valgrind -zeroconf" 1,510 KiB
[ebuild  N     ]     media-plugins/alsa-plugins-1.2.7.1-r1::gentoo  USE="mix pulseaudio usb_stream -arcam_av -debug -ffmpeg -jack -libsamplerate -oss -speex" ABI_X86="(64) -32 (-x32)" 400 KiB
[ebuild  N     ]     media-libs/libsndfile-1.2.0::gentoo  USE="alsa -minimal -sqlite -test" ABI_X86="(64) -32 (-x32)" 714 KiB
[ebuild  N     ]      media-sound/mpg123-1.31.3::gentoo  USE="alsa ipv6 pulseaudio sdl (-coreaudio) -int-quality -jack -nas -oss -portaudio" ABI_X86="(64) -32 (-x32)" CPU_FLAGS_X86="sse (-3dnow) (-3dnowext) (-mmx)" 1,069 KiB
[ebuild  N     ]       media-libs/libsdl2-2.26.2::gentoo  USE="X alsa dbus gles2 joystick opengl pulseaudio sound threads udev video vulkan wayland (-aqua) (-custom-cflags) -doc -fcitx4 -gles1 -haptic -ibus -jack -kms -libsamplerate -nas -oss -pipewire -sndio -static-libs -xscreensaver" ABI_X86="(64) -32 (-x32)" CPU_FLAGS_X86="mmx sse sse2 -3dnow" VIDEO_CARDS="(-vc4)" 7,895 KiB
[ebuild  N     ]  media-libs/libcanberra-0.30-r7::gentoo  USE="alsa gnome gstreamer gtk3 pulseaudio sound udev -gtk2 -oss -tdb" ABI_X86="(64) -32 (-x32)" 312 KiB
[nomerge       ] media-sound/mpg123-1.31.3::gentoo  USE="alsa ipv6 pulseaudio sdl (-coreaudio) -int-quality -jack -nas -oss -portaudio" ABI_X86="(64) -32 (-x32)" CPU_FLAGS_X86="sse (-3dnow) (-3dnowext) (-mmx)"
[ebuild  N     ]  media-sound/pulseaudio-16.1::gentoo  USE="bluetooth glib -daemon -jack -ofono-headset" ABI_X86="(64) -32 (-x32)" 0 KiB
[ebuild  N     ]   media-libs/libpulse-16.1-r2::gentoo  USE="X asyncns dbus glib gtk systemd -doc (-selinux) -test -valgrind" ABI_X86="(64) -32 (-x32)" 0 KiB
Total: 10 packages (10 new), Size of downloads: 28,532 KiB
 * Error: circular dependencies:
(media-libs/libsndfile-1.2.0:0/0::gentoo, ebuild scheduled for merge) depends on
 (media-sound/mpg123-1.31.3:0/0::gentoo, ebuild scheduled for merge) (buildtime_slot_op)
  (media-sound/pulseaudio-16.1:0/0::gentoo, ebuild scheduled for merge) (buildtime)
   (media-libs/libpulse-16.1-r2:0/0::gentoo, ebuild scheduled for merge) (buildtime)
    (media-libs/libsndfile-1.2.0:0/0::gentoo, ebuild scheduled for merge) (buildtime)
It might be possible to break this cycle
by applying any of the following changes:
- media-libs/libsndfile-1.2.0 (Change USE: +minimal)
- media-sound/mpg123-1.31.3 (Change USE: -pulseaudio)
Note that this change can be reverted, once the package has been installed.
Note that the dependency graph contains a lot of cycles.
Several changes might be required to resolve all cycles.
Temporarily changing some use flag for all packages might be the better option.
Output doesn’t look vastly different from what I’d seen before…
OK, You are logged into your root account? At this point with Gentoo I will do a emerge -avuND world and this will update your packages. You are going to need a user account, before you start installing a lot of packages, including vim.
We will get to vim!!!
Update your packages with emerge -avuND world
Seup user account with useradd -m -G users,wheel,video,audio,portage,cdrom,usb -s /bin/bash your user name
passwd your user name
emerge --ask app-admin/sudo
visudo /etc/sudoers to edit the sudoers file
If all goes well reboot and login to you user account
We can then move on to the important stuff
Cheers mate - I might leave that till tomorrow or the day after…
do all that without vi, will be tiring :smiley:
I’m 100% comfortable with useradd, visudo (except I won’t be able to ā€œexport EDITOR=viā€) et cetera…
Cheers for all your help so far…
This isn’t very ā€œUNIXā€ - needing a user subsystem to have a basic text editor vi… I assume that emacs would be even harder? I guess I can’t complain, imagine if gentoo made everyone use ā€œexā€ā€¦ :smiley:
trust me you will not need vi you can even use nano to edit /etc/sudoers
No, no. That is not vim being masked, it is something else.
@4dandl4 answered that for me
OK take redistributable pulseaudio out of make.conf and rerun emerge -avuND world.
So remove those use flags.
Yes it is, daniel needs to setup his user account before moving on!!!
!!! The following installed packages are masked:
- app-admin/eselect-1.4.22::gentoo (masked by: package.mask)
It says it is masking eselect ?
I agree he needs a user before doing emerge
@nevj
I got hit with the sys-devel/llvm and sys-devel/clang update with my Gentoo, it is taking a little time too emerge -avuND world.
How did you come to use llvm compiler? Mine uses gcc.
I think I understand that masking. It has turned off eselect to stop all installs because there is no user. What do you think? That is a rather backhanded approach.
I have no idea but one of my use flags must need as a dependence.
Their are Gentoo restrictions when using the root account. I add the Gentoo user account as soon as I have the Gentoo CLI compiled, along with sudo.
Wow. I’m glad I have my golf game for my unsolvable problem. It’s easier than Gentoo. My computers are quite content with any .deb distro.
@berninghausen and @easyt50
Oh come on try Gentoo in VirtualBox, we can then have a round house Gentoo discussion group. Never be content with the distro you are running.
