As the title indicates, I ran into a new issue not encountered before.
On my laptop (running Pop OS), the external HDD has 2 partitions. One is for media storage (NFTS) and the other for my backups as well as my home directories (ext4). My symlinks in Pop point to this location. Has been this way for over 6 months now, since I removed Windows from the machine.
Couple of days ago, I downloaded something and noticed the notification “Download Failed” I tried it 2x unsuccessfully.
Last night, I tried to download something different and got the same notification. So I went to investigate in file manager by choosing download folder.
I then got the message: “Downloads could not be found. Perhaps it has been deleted.”
Whoa, what? So I looked at the sidebar in file manager, where all my home folders reside and everyone of them gave the same error message. Then I noticed that the external HDD first partition was shown, mounted at /media but the second partition was missing.
Opening disks, I saw the parition I had created, “Linux Acer ES” and it was mounted on /run/timeshift/backup. This is where my home directories reside so my symlinks were now broken due to TS mounting the disk elsewhere.
I researched this and found several recent instances where this has been complained about: TS remounts the drive during backups and does not unmount/remount it to its previous location. Therefore, the drive is unavailable in file manager.
But I do not understand what changed over a period of six months since I have never had the broken symlinks before now.
This computer only has one internal SSD so I use one of my ext 5 TB HDDs for things needed to be kept separate from the OS partition. And I always keep /home on a separate drive.
So having timeshift pointed to this partition for backups means I cannot have my /home folders reside there as well?
I have recently created the NFS partition for the server, and it shows up in file manager, as well as the other partition on that same ext HDD. So only the ext 4 partition that TS uses no longer does.
Has anyone else experienced this? I am trying to think how to fix this without moving everthing around, repartition that partition to include yet another partition just for TS, or having to constantly remount the partition where my/home folders reside.
Thanks,
Sheila Flanagan
