My new laptop has a fairly high resolution LCD screen, 2880 x 1800. It’s running Ubuntu 22.04.3 LTS, all updates installed.
Everything looks great on the screen except for Moneydance, which I use to keep my checkbook register. The text and numbers in the Moneydance window are tiny, even though it’s set to the largest font size in the Moneydance preferences. It’s quite sharp but it’s very small.
If I enlarge the window all that happens is the blank spaces on the page expand but the text does not change size. Using Gnome Tweaks to increase the minimum font sizes has no effect, nor does increasing the scaling factor. Hitting CTRL+ has no effect. (There is a “Scale” adjustment in Settings > Displays with choices of 100%, 200%, and 300%. Only 200% is a viable choice, the others being way too small or too large and a bit blurry when fractional scaling is activated.)
It seems that Moneydance writes to the screen in a way that bypasses Ubuntu’s settings. I worked with the Moneydance tech support folks without finding an answer.
Any suggestions?
