–Hello, I installed UM 22.04 and then proceeded to copy and paste my T-bird and Home folder from my UM 20.04. I started to add apps to the top panel, like Diodon, Screenshot, etc from the Accessories menu, and for some reason I got stupid and I Reset Panel the top panel.
I now had no way to shut the computer off except for holding down the start button. I was sick… I rebooted and the top panel showed up but was very much different from the original one.
The App Diodon in the Software Boutique showed that it was installed. I reinstalled it and and it never showed up. When I go to Edit Menus there is not much there, just whats showing in the Application - Places - System.
Please help… I’m old, over 70, and not real tech savvy. But I know I like Ubuntu WAY, WAY more than Windows. Who wouldn’t?
I have other issues also, and will be back to annoy everyone. One at a time…
Hi @toasted.slug
It is difficult for me to help , because I do not use Ubuntu, and you do not say which desktop environment you are using.
Some basic things that might help
the background menu ( right click on the background) might have a
shutdown button
you can always shutdown using the command line.
Just type sync
and then halt as superuser, or sudo halt
there must be a menu in your desktop that controls the panels. You need to find that menu and use it to redefine the top panel and its contents.
to protect yourself from this sort of thing in the future, you need to do regular backups.
Nevilles
Thanks Neville, I am using Mate (UM). There has to be a way to reestablish the Top Panel to its original
state. I have I can turn the computer off now, and have entered some icons (apps) to it. When I shut down the box, a lot of the apps go missing and I have to enter them again.
I am a 70-something, definitely NOT a Linux geek (modestly informed amateur), and I use Maté. There are but two tips I can suggest. One is, you can always shut down, regardless of the top panel issue, by starting the terminal and enter shutdown.
For that top panel, Mate Tweak is what I used, and I chose “classic” as my theme.
First, follow Rosika’s links. They will obviously be more helpful.
