I have been using computers and keyboards since 1977.
When forced to use a mouse pad / Touch pad, I get nuts.
So, with Windows on the laptops/notebooks I have TouchPad Blocker by KARPOLAN installed.
Has anyone tried Touchfreeze ?
Good laptops allow you to disable the Touchpad entirely in the BIOS/UEFI.
Thank you !
How should I know that was possible ?
P.s. DELL Latitude e4310 have only one USB port.
I do not trust installing a distro via a hub ; so I think I need that mouse pad during installation ; but I will now be able ( thanks to you ) to disable it from the BIOS when I keep a distro.
Why? Should be possible, most of the time. Except you are using an extremely cheap USB hub.
I’ll try it next time and let you know.
In MATE I have an option to disable touchpad while typing.
@kovacslt, @Akito
When I said I did not trust the hub
I meant I am not certain I can do that.
And, you are right ; I can’t boot from a stick attached to a hub.
It is probably cheap.
Want to see it :
Now please do not laugh at me.
Indeed, looks very cheap.
