TPM 2.0 in Ubuntu
Hello, I’m looking a guide to install and configure correctly the TPM 2.0 in my Ubuntu 20.04.
I’ve searching any guide on Google but the most of this guides are out of date or don’t explain the process correctly.
Can someone provide me with a good link or guide for this?
Thanks.
Hi
Here is a link that may help, as it is for TPM2: TPM - Ubuntu Wiki
Most of the other resources I found are for the Windows OS and UEFI boot.
Robert
@nos
The TPM settings is in your Motherboard bios. I just built s PC using a MSI mobo and the TPM had to be enabled, before I installed W11. Mobo are different, but my two options were enable, “PPP or DTPM” the PPP is to enable the cpu setting and the dtpm was to enable, if one has a TPM Module, which I had, and is the one I enabled. Hope this helps.
