System:
Host: joey-Z140C Kernel: 4.15.0-69-generic x86_64 bits: 64 compiler: gcc
v: 7.4.0 Desktop: Cinnamon 4.2.4 Distro: Linux Mint 19.2 Tina
base: Ubuntu 18.04 bionic
Machine:
Type: Laptop System: Mustek product: Z140C v: 1.0 serial: <filter>
Mobo: Mustek model: YN8DE serial: <filter> UEFI: American Megatrends
v: 8.16 date: 10/26/2018
Battery:
ID-1: axp288_fuel_gauge charge: 83% condition: N/A model: N/A
status: Charging
CPU:
Topology: Quad Core model: Intel Atom x5-Z8350 bits: 64 type: MCP
arch: Airmont rev: 4 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 11520
Speed: 480 MHz min/max: 480/1920 MHz Core speeds (MHz): 1: 610 2: 483
3: 480 4: 480
Graphics:
Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series
PCI Configuration Registers
driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.6 driver: modesetting unloaded: fbdev,vesa
resolution: 1366x768~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics (Cherrytrail)
v: 4.5 Mesa 19.0.8 direct render: Yes
Audio:
Imaging Unit
driver: N/A bus ID: 00:03.0
Sound Server: ALSA v: k4.15.0-69-generic
Network:
Message: No Device data found.
IF-ID-1: wlan0 state: up mac: <filter>
Drives:
Local Storage: total: 43.74 GiB used: 15.78 GiB (36.1%)
ID-1: /dev/mmcblk0 model: SLD32G size: 28.91 GiB
ID-2: /dev/mmcblk2 model: SC16G size: 14.84 GiB
Partition:
ID-1: / size: 27.83 GiB used: 15.78 GiB (56.7%) fs: ext4
dev: /dev/mmcblk0p2
Sensors:
System Temperatures: cpu: 53.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info:
Processes: 200 Uptime: 10d 1h 57m Memory: 1.87 GiB used: 1.10 GiB (58.5%)
Init: systemd runlevel: 5 Compilers: gcc: 7.4.0 Shell: bash v: 4.4.20
inxi: 3.0.32
I use an HP Stream which, with it having no HDD, I find it perfect (for example to have my vehicles manuals available in a very easily portable and robust device). I have installed a 32 GB micro card with no problems.
Now the above print out is from a similar Mecer that I got for my wife who loves to play card games and has many photographs she needs easy access to - I felt that this type of Laptop would be ideal for her.
I have Mint 19.2 (Cinnamon) on both the above machines.
Now my problem: When I installed a 16 GB micro card into the micro slot on her Mecer it is not âseenâ by the laptop although it is in fact shown as one of the drivesâŚ
However, if I place the 16 GB micro card via a USB adapter into a USB slot it shows up perfectlyâŚ
Hope I am making a simple mistake!!
Many thanks
Clive Liddell
Pietermaritzburg
South Africa
