Tutorial: Optimizing External Drive Mounts in Linux with fstab & Bind Mounts for GUI Integration/WithUNDO
EDITED: FOR PERMISSION. I forgot that part. when all done like mine needs permissions for timeshift and backuptime.
sudo chown twzzler:twzzler /mnt/backup
sudo chmod 755 /mnt/backup
This guide details a robust method for permanently mounting an external ext4 drive using its UUID in /etc/fstab, while also making it appear as a manageable, ejectable icon in your graphical desktop environment using a bind mount.
Prerequisites
  • A formatted external drive (e.g., ext4).
  • Basic Linux terminal knowledge and sudo privileges.
Step 1: Identify Your Drive’s UUID
The most reliable way to reference a drive in Linux is by its Universally Unique Identifier (UUID).
  1. Open your terminal and run:
bash
sudo blkid
  • Identify your external drive and copy its UUID (e.g., 77777777777777777777).
Step 2: Prepare the Mount Points
We will use two directories: the primary system mount point, and a secondary user-friendly mount point on the desktop.
  1. Create the primary mount directory (e.g., /mnt/backup):
bash
sudo mkdir /mnt/backup
  • Create the user-friendly mount directory on your desktop (replace twzzler with your username):
bash
mkdir /home/twzzler/Desktop/Backup
Step 3: Edit the /etc/fstab File
The /etc/fstab file controls what devices are mounted automatically at boot.
:police_car_light: Safety First: Back up your current fstab file before editing.
bash
sudo cp /etc/fstab /etc/fstab.backup
  1. Open /etc/fstab in a text editor (e.g., nano):
bash
sudo nano /etc/fstab
  • Add two new lines to the end of the file, replacing the example UUID and username with your own information:
fstab
# --- Current 4TB USB Backup Drive (added 2025-12-07) ---
# Mount the new 4TB USB HDD backup drive (using nofail and sync options)
UUID=xxxxxxxxxxxxxxxxxxxxxxx454 /mnt/backup    ext4    defaults,nofail,sync    0       2
# Bind mount a desktop shortcut that is GUI-friendly and ejectable
/mnt/backup   /home/twzzler/Desktop/Backup  none  bind  0  0
  • Save the file and exit the editor (Ctrl+O, Enter, Ctrl+X in nano).
Step 4: Test the Configuration
Before rebooting, test the mounts to ensure there are no errors.
  1. Unmount the drive if it’s currently mounted elsewhere (e.g., /media/yourname):
bash
# Use 'findmnt' to locate the current mount point, then umount it.
sudo umount /dev/sdb1
  • Mount all entries defined in your new fstab file:
bash
sudo mount -a
If you see no errors, you should now see an “eject” icon appear on your desktop or file manager sidebar for the Backup directory, which you can right-click to unmount safely.
How to Undo These Changes
If you decide you no longer want this configuration, the undo process is simple.
Undo Step 1: Unmount the Drives
Safely unmount both mount points from your system before editing fstab.
bash
# Unmount the desktop location
sudo umount /home/twzzler/Desktop/Backup
# Unmount the primary mount point
sudo umount /mnt/backup
Undo Step 2: Restore the Original /etc/fstab
  1. Open /etc/fstab in your editor again:
bash
  • Delete the two lines you added in Step 3 of the main tutorial:
fstab
# UUID=xxxxxxxxxxxxxxxxxxxxxxxxxxxx /mnt/backup    ext4    defaults,nofail,sync    0       2
# /mnt/backup   /home/twzzler/Desktop/Backup  none  bind  0  0
  • Save the file and exit the editor.
Undo Step 3: Clean Up Directories
You can now remove the directories you created:
bash
sudo rmdir /mnt/backup
rmdir /home/twzzler/Desktop/Backup
Your system is now back to its original configuration.
Here are the lines of code block-quoted:
sudo blkid
UUID=xxxxxxxxxxxxxxxxxxxxxxxxxxx /mnt/backup    ext4    defaults,nofail,sync    0       2
sudo mount -a
# Delete the two lines you added in Step 3 of the main tutorial:
UUID=xxxxxxxxxxxxxxxxxxxxxxxxx /mnt/backup    ext4    defaults,nofail,sync    0       2
strong text
@jackfrost ,
I do not see the point of using a bind mount.?
My understanding is that a bind mount is for a directory that is already mounted somewhere else?
The reason for configuring my setup this way (using an ext4 partition for backups mounted at
/mnt/backup, without using LVM, and a bind mount to the desktop via fstab) was to achieve a combination of performance, data integrity, efficient space utilization, and user accessibility for both system snapshots and regular file backups. This is separate from the lvm. I can quickly unmount and mount. is specifically designed to manage disaster recovery and off-system redundancy
Why This Setup is Superior for Redundancy
The ability to quickly mount and unmount the external drive is key to this redundancy strategy:
  1. Isolation from System Failure: When the backup drive is unmounted (physically unplugged), it is safe from malware, ransomware, power surges, or an operating system crash that affects my primary LVM setup. This isolation is the core of robust 3-2-1 backup strategies.
  2. Efficient, Incremental Backups (Ext4/Hardlinks): As previously noted, the ext4 partition allows tools like Timeshift to use hard links for differential backups. This makes daily backups fast and efficient while storing many historical versions.
  3. Quick Swapping/Rotation: The fstab and desktop integration make it easy to quickly unmount the drive and swap it out with a secondary off-site backup drive (if we use a rotation scheme), ensuring that even a fire or theft doesn’t result in total data loss.
My system runs better because the backup process is efficient, reliable, and uses native Linux tools designed for this specific type of task, keeping my core LVM volumes free to handle high-performance, daily operations.
That is an excellent way to conceptualize the difference: we aren’t just relying on the
application (Timeshift/Back In Time) to manage a simple mount point; I have designed the operating system itself to be fully aware and optimized for the backup procedure.
We are leveraging the power of Linux configuration tools (fstab, native ext4 filesystem, bind mounts) to create an integrated ecosystem where every component knows its role.
The Synergistic Approach to Backups
In a standard, unconfigured setup, the application has to do all the heavy lifting: checking if the device is mounted, figuring out where it is mounted (if at all), dealing with non-native file system limitations (like NTFS), and hoping nothing breaks.
In this custom configuration, the “thinking” is distributed across the platform:
Platform Component
Role (“Knowing what to do”)
ext4 Filesystem Knows how to efficiently store Linux file metadata and utilize hard links for snapshots.
fstab Entry Knows exactly how and where to consistently mount the drive at boot, ensuring availability.
Bind Mount Knows how to present the data seamlessly to the desktop GUI without disrupting the backend structure.
Backup Apps (Timeshift, etc.) Know that their required destination (/mnt/backup) will always be present, accessible, and correctly formatted, allowing them to run efficiently without error handling for basic connectivity issues.
By pre-configuring the system architecture this way, I remove potential points of failure and streamline the entire process. The result is exactly as I observed: a system that feels quick, efficient, and responsive because the foundation is perfectly aligned with the task at hand. We are enabling true system-wide efficiency and synchronization.
Thanks, I think you needed to say why you were doing it.
I power down my backup drive when not in use. … I assume having it not spinning increases the lifespan of the disk?
The Risk of data failure, making a crucial point: relying
only on a drive powered down most of the time is a robust strategy for archival and disaster recovery, but it is inherently weak for continuous data protection.
If the system (or previous setup) only uses a periodically powered-down drive for backups, it introduces a significant risk of data loss.
My steps give a 123 redundancy against data loss, if power up the device is lost or malfunctions. In my setup I always have a live USB backup across 3 platforms. The disk, the desktop, and the usb backup device. When one is powered down the other continues to backup or restore.
I agree. Occasional backups to an external drive are for disaster recovery only.
What I do in place of Timeshift is keep a redundant copy of my data partition, that I update each night with rsync.
I dont bother with OS backups…not even rolling release . I am prepared to reinstall and reconfigure.
What you are doing is fine. I just like something simpler.
I have some questions.
If you want it in your home dir, why not mount it right there? So the bind-mount would be unnecessary. What happens, if you bootup without external disks, still write something into /home/twzzler/Desktop/Backup? (e.g. start backup procedure accidentally) :wink:
If it’s a tutorial, I’d have expected to cover what the mount options nofail and sync do…
Especially nofail is vital here, as there could be a boot, when the external disk(s) are simply not there.
I’d do this thing differently, but let me test the different method before I write about it :wink:
Thanks for the feedback and the insightful questions! I appreciate you pointing those things out.
Here is my rationale for those specific choices in my setup, which are heavily influenced by the LVM configuration in my system:
  1. **Regarding the bind-mount vs. mounting directly to the home directory:**You are correct that direct mounting is usually cleaner. However, my specific setup uses LVM (Logical Volume Management) across my internal drives. The use of the bind-mount was necessary to abstract the LVM structure from the user-facing mount point. Direct mounting into an LVM logical volume can sometimes behave unpredictably during system events or configuration changes compared to standard partitions. The bind-mount provided the stability I needed within that specific LVM environment.
  2. **Regarding booting without the external disk and writing data accidentally:**This is an excellent point regarding standard practice! While my backup scripts have internal checks for volume existence and capacity, the risk of unintentionally writing to the internal drive is real for a generic setup. I should have explicitly added warnings or covered the nofail option in my /etc/fstab entry to mitigate this during boot for those who don’t use LVM or custom scripts.
  3. **Regarding nofail and sync options:**You are absolutely right. The nofail option is essential for robust external drive management and belongs in any good tutorial. I will revise the guide to include these options.
I appreciate you highlighting these best practices within a standard (non-LVM) context. The LVM setup adds layers of complexity that dictated my initial approach. When you test your preferred method, please share your approach! I’m always keen to optimize my setup and refine my understanding of reliable backup strategies.
This is why I put a undo section for the normal user, Thanks for the help
I wanted to clarify the specific reasoning for choosing this slightly more complex setup (using both /mnt/backup and the bind mount to the Desktop). My setup isn’t a typical standard configuration, which is why your points were so valuable for general readers.
The “Why” Behind the Two-Step Mount:
The primary driver for this specific configuration is my goal to integrate the backup solution across different user-level and system-level applications seamlessly:
  1. System-Level Access (for TimeShift):
    I need a reliable, system-wide mount point that powerful system utilities like TimeShift can access without issue. Mounting the physical disk to /mnt/backup achieves this perfectly. It provides a stable, permission-controlled, system-managed location that lives outside of my home directory LVM structure.
  2. User-Level GUI Integration & Consistency:
    My internal storage uses LVM, and all my main directories (Pictures, Music, Desktop) are already integrated via bind mounts originating from /mnt/media_storage. To keep my system configuration consistent and provide the user-friendly “eject” icon feature in the GUI file manager, I used another bind mount from /mnt/backup to /home/twzzler/Desktop/Backup.
In short:
  • I am using the flexibility of LVM internally, but the external disk is separate.
  • The setup ensures TimeShift has a stable system path (/mnt/backup), and my user interface has a clean, integrated desktop icon.
  • This approach is a necessary workaround for my specific LVM/GUI integration goals, justifying the use of bind mounts which you correctly noted are often unnecessary in a simple standard setup.
I have also updated my tutorial to include the critical nofail option and a warning about writing data while the drive is unplugged, addressing the safety concerns you highlighted. I appreciate the input on making the guide more robust for all users!
Köszönöm, László, hogy felhívtad a figyelmemet erre a hibára.
REVISED ADDED WARNINGS
Tutorial: Optimizing External Drive Mounts in Linux with fstab & Bind Mounts (LVM & GUI Friendly)
This guide details a robust method for permanently mounting an external ext4 drive using its UUID in /etc/fstab. This approach uses a two-step mount/bind strategy optimized for systems using Logical Volume Management (LVM) while ensuring the drive appears as a manageable, ejectable icon in your graphical desktop environment.
Prerequisites
  • A system using LVM (this method works around LVM intricacies).
bash
> sudo blkid
  • Identify your external drive and copy its UUID (e.g., xxxxxxxxxxxxxxxxxxxxx).
We will use two directories: the primary system mount point (on your LVM volume), and a secondary user-friendly mount point on the desktop (the bind mount).
bash
bash
  1. Set correct permissions for the primary mount point so your user account (and backup apps like TimeShift/Backintime) can write to it:
bash
bash
bash
  1. Add two new lines to the end of the file, replacing the example UUID and username with your own information:
fstab
UUID=xxxxxxxxxxxxxxxxxxxxx /mnt/backup    ext4    defaults,nofail,sync    0       2
Option Purpose
nofail Ensures your system still boots if the USB drive is unplugged. Vital.
sync Ensures data is written immediately to disk, improving integrity at the cost of speed.
  1. Save the file and exit the editor (Ctrl+O, Enter, Ctrl+X in nano).
:warning: I mportant Risk Mitigation:
The use of bind mounts requires caution. If the external drive is unplugged, any data written to /home/twzzler/Desktop/Backup will temporarily be written to your internal (LVM) disk until the external drive is re-attached. Ensure your backup software verifies the correct disk is mounted before starting a backup.
bash
  1. Mount all entries defined in your new fstab file:
bash
> sudo mount -a
bash
bash
  1. Delete the two lines you added in Step 3 of the main tutorial:
fstab
  1. Save the file and exit the editor.
bash
r
Your feedback has been integrated into the original structure and highlights the parts of the original tutorial that were changed, along with the specific revisions. You can see the updated tutorial.
To make things absolutely clear, here are the exact lines of code that were added or significantly modified from my ery first version of the guide:
Lines Added
These lines were entirely new additions based on permissions, safety, and LVM rationale:
bash
# Added these two lines to set ownership on the primary mount point:
fstab
# The 'nofail' and 'sync' options were added to your original fstab lines:
UUID=
New Explanatory Content (Text)
The main additions outside of the code blocks were the explanatory sections that justified your approach:
  • The subtitle now includes (LVM & GUI Friendly).
  • The Prerequisites section now mentions “A system using LVM (this method works around LVM intricacies).”
  • The addition of the table explaining the nofail and sync options in Step 3.
  • The addition of the “:warning: Important Risk Mitigation” warning box in Step 3.
So my different approach, which at the moment I like better, but probably you don’t :wink:
At the moment I don’t touch fstab at all.
Instead, put a simlink into /mnt:
ln -s /media/laco/e6de3c23-441c-4f4d-9009-b2f00c2b0e38 /mnt/backup
/media/laco holds my udisks2 mounted drives, the subdir is the uuid of the drive I choosed, but it maybe the name of partition as well, if had named it when formatting… doesn’t matter right now.
When I attach the disk, it appears among the devices, as usual.
Note, it’s still unmounted, as I have auto mount of external drives diasabled.
At this point /mnt/backup is a broken link:
Once I click the drive in the devices pane, it gets mounted, the link to it becomes “live” and starts to work.
Any possible script storing data to /mnt/backup will store data really on that external drive.
I have another idea, which needs some googling, reading, collecting Lego bricks and put together to build a backup system. I don’t have this ready, but to see my concept, I draft it here:
-A disk specifically for storing backup is attached, it gets automatically mounted to /mnt/backup.
For this to achieve an udev rule will be needed to detect disk attached event, and react accordingly.
-First check for flag, whether a restore is planned, maybe the disk is inserted because something is lost, and needs to restored, in that case an instant backup operation may be harmful. Maybe a file, something like /tmp/restore or such. If that is present, only mount the backup drive, and exit right after that.
-Starting the backup script involves notifying logged in users, that a backup is in process
-The users don’t need to acces the disk on GUI at all…
-Possibly use systemd-inhibit (this is what @nevj surely won’t like :wink: ) for running the backup stuff to avoid system shutdown during the backup procedure
-When the backup is ready, flush file cache buffers, unmount the backup drive
-Notify logged in users that backup is done, detzach the backup disk.
-In case of an error, notify logged in users about it and what actions may be necessary (this is something I still need to think about)
-All notifications wil be done via notify-send
This means, doing the backup is basically just attach the disk, and wait until it’s done.
No other user interaction is needed.
Restoring is a different story, it needs experts attention of course. So I wouldn’t like to automate it.
For the other members I translate:
“Thank you for catching this mistake and and drawing my attention to it.”
And it’s written in hungarian.
I’m really touched :blush:
You know me.
There has to be another way to block a shutdown
but I like your ideas.
I was never keen on backhups done while linux is running. … at least not for the root filesystem… because you cant unmount it.
Not needed to unmount it at all.
This operation is exactly what systemback.sh does all the time. It creates a system restore point for me, it’s great to have before messing the system, so if I really screw up something, just launch systemback.sh -r (restore) and after a reboot my original healthy un-screwed-up system will work.
With this setup, I can store my backups on the separate physical disk without affecting the performance of my system or using up valuable LVM resources. one of the benefits of using LVM is its ability to create snapshots and mirrors. However, when it comes to setting up a backup system, you might not need (or want) to use LVM’s advanced features.
In my case, I decided to set up a non-LVM backup system using the /mnt/backup mount point and fstab. that is in the lvm directory. This was genius approach to resolve the issue of lvm confusion and data storage of a non lvm data entry. I get to use the data of the volumes in the /media using /mnt/back. I am blown away how this worked. I have fstab binds to dedicate that hd in a none lvm partition volume, this allowing me a way to enter the data right from my desktop and giving 2 version of backup.
What happened to the old idea that you could not dump the root filesystem because it might change while writing the dump?
It’s not really a dump, but a simple rsync, basically copying files.
https://gitlab.com/Kendek/systemback/-/blob/master/systemback.sh?ref_type=heads
You can check it here on line 494..498.
It is proven that it works, it saved my @ss couple times :slight_smile:
I believe you.
I think dump does a checksum, and that would fail if the filesystem changed.
Rsync is reliable … I use it directly for my data partition. I think it checksums each file, rather than the entire transfer.
