Are you sure?
Note, that the filename is the same for Ubuntu 22:
https://download1.rstudio.org/desktop/jammy/amd64/rstudio-2022.07.2-576-amd64.deb
The download URL differs, note the âbionicâ in my link, and âjammyâ here.
The .deb packages are different. Based just on the filename itâs impossible to tell which version you really downloaded. Also checking the hash would tell surely, which you have, the filesize gives a hint too.
But no problem if Iâm wrong, itâs not unusal
But get back your problem.
There are some practices, youprobably donât know yet.
If you did not use a filesystem encryption, accessing your data on your damaged Linux installation is fairly easy.
First, boot up live USB!
You will get a fully working environment, youâll be able to mount partitions, disks on your system. You can use the filemanager of the liveUSB to mount any partition on your computer, be it on the on the built-in SSD/HDD, or on a just attached external HDD.
Just browse the contents of the folders, do copy/paste (preferably from source to destination
Your data you might want to backup is stored in your home folder. Thatâs something like /home/your_username/, so look for a derictory called your_username under a âhomeâ diretory.
So backing up your data is not more difficult, than copy files and dirs from a disk to another. Just substitute your_username with your actual login name on your installed system.
Maybe this video shows some of the basic ideas
Regarding making your system bootable, as I mentioned, Iâd chroot into it.
Now I try to give some hints to that:
you have your liveUSB booted up.
If you mounted some partitions, disks using the filemanager, unmount them.
Start a terminal (ctrl-alt-T usually does this).
Get root, to avoid to having to type too many âsudoâ commands, Iâm awfully lazy, so I always do this. So in the terminal:
sudo su
I assume, you already know whereâs your system installed. I mean disk and partition. For the simplicity letâs say itâs sda1. Itâs the first partition of the sda disk.
I would mount it to /mnt, so in the terminal:
mount /dev/sda1 /mnt
So if you know cd to /mnt, youâll see the contents of your system partitions.
If you have it on a different disk or partition, substitute /dev/sda1 with your actual values.
Iâd try to chroot into that installed system, that basically means, any commands do things on the installed system, changes made via apt remove affect that installed system. So in the terminal:
chroot /mnt
Youâll get a root shell, and whatever you now, you do it with your installed system.
Iâd try to remove rstudio packages:
apt purge rstudio*
apt autoremove --purge
Both commands will ask you for a confirmation wether you really want to remove those packages.
Exit from chroot, unmount your partition and reboot:
exit
umount /mnt
reboot
See, if your system works?
