Hi all,
Ive been running PhotoLine with Wine in Ubuntu. This has worked well, even with version 23.00, however, when I try to install version 23.50 or 23.51: PhotoLine: Download I am not able to install and I get the following message Im wondering if anyone understands:
Unhandled exception: unimplemented function mscms.dll.WcsGetUsePerUserProfiles called in 64-bit code (0x000000007bc5b50c).
Register dump:
rip:000000007bc5b50c rsp:000000000023cca0 rbp:000000000023ce70 eflags:00000206 ( - – I - -P- )
rax:0000000180000100 rbx:000000000023ccc0 rcx:000000000023ccc0 rdx:00000001407735f0
rsi:0000000141f93c2e rdi:0000000141f93c48 r8:000000000023ce20 r9:0000000000000000 r10:000000000000002f
r11:0000000000920288 r12:ffffffffffffffff r13:0000000000000001 r14:00000001421be040 r15:0000000000000000
Stack dump:
0x000000000023cca0: 000000000023ccc0 0000000000000000
0x000000000023ccb0: 0000000000000000 0000000000000000
0x000000000023ccc0: 0000000180000100 0000000000000000
0x000000000023ccd0: 000000007bc5b50c ffffffff00000002
0x000000000023cce0: 0000000141f93c48 0000000141f93c2e
0x000000000023ccf0: 0000000000000000 0000000000000000
0x000000000023cd00: 0000000000000000 0000000000000000
0x000000000023cd10: 0000000000000000 0000000000000000
0x000000000023cd20: 0000000000000000 0000000000000000
0x000000000023cd30: 0000000000000000 0000000000000000
0x000000000023cd40: 0000000000000000 0000000000000001
0x000000000023cd50: 0000000000000000 61f3cb71b87e1100
Backtrace:
=>0 0x000000007bc5b50c in ntdll (+0x3b50c) (0x000000000023ce70)
1 0x00000001407735f0 in photoline (+0x7735ef) (0x000000000023ce70)
2 0x00007fb746f07add X11DRV_EnumDisplayMonitors+0x12c() in winex11 (0x000000000023d640)
3 0x00007fb74ba57ce9 EnumDisplayMonitors+0x18() in user32 (0x000000000023d670)
4 0x0000000140773a19 in photoline (+0x773a18) (0x000000000023d7f0)
5 0x00000001406ddd29 in photoline (+0x6ddd28) (0x000000000023d7f0)
6 0x0000000140cdd3bb in photoline (+0xcdd3ba) (0x000000000023d7f0)
0x000000007bc5b50c: addq $20,%rsp
Modules:
Module Address Debug info Name (128 modules)
ELF 7b400000- 7b80d000 Deferred kernel32
-PE 7b420000- 7b80d000 \ kernel32
ELF 7bc00000- 7bd16000 Dwarf ntdll
-PE 7bc20000- 7bd16000 \ ntdll
ELF 7c000000- 7c004000 Deferred
PE 140000000- 1426ac000 Export photoline
PE 7fb74068c000- 7fb74089f000 Deferred api-ms-win-core-localization-obs
PE 7fb740690000- 7fb74089f000 Deferred api-ms-win-core-localization-obsC:\windows\system32\api-ms-win-core-localization-obsolete-l1-2-0.dll
ELF 7fb74089f000- 7fb740ab2000 Deferred api-ms-win-core-datetime-l1-1-1<
PE 7fb7408a0000- 7fb740ab2000 Deferred api-ms-win-core-datetime-l1-1-1
ELF 7fb740ab2000- 7fb740cc5000 Deferred api-ms-win-core-string-l1-1-0<el
PE 7fb740ac0000- 7fb740cc5000 Deferred api-ms-win-core-string-l1-1-0
PE 7fb740cc5000- 7fb740ed9000 Deferred api-ms-win-core-localization-l1-
PE 7fb740cd0000- 7fb740ed9000 Deferred api-ms-win-core-localization-l1-C:\windows\system32\api-ms-win-core-localization-l1-2-1.dll
ELF 7fb740ed9000- 7fb7410ec000 Deferred api-ms-win-core-fibers-l1-1-1<el
PE 7fb740ee0000- 7fb7410ec000 Deferred api-ms-win-core-fibers-l1-1-1
ELF 7fb7410ec000- 7fb741300000 Deferred api-ms-win-core-synch-l1-2-0<elf
PE 7fb7410f0000- 7fb741300000 Deferred api-ms-win-core-synch-l1-2-0
ELF 7fb741300000- 7fb741515000 Deferred libgpg-error.so.0
ELF 7fb741515000- 7fb741831000 Deferred libgcrypt.so.20
ELF 7fb741831000- 7fb741a4d000 Deferred liblz4.so.1
ELF 7fb741a4d000- 7fb741c73000 Deferred liblzma.so.5
ELF 7fb741c73000- 7fb741ef7000 Deferred libsystemd.so.0
ELF 7fb741ef7000- 7fb7420ff000 Deferred libffi.so.6
ELF 7fb7420ff000- 7fb742319000 Deferred libresolv.so.2
ELF 7fb742319000- 7fb74251d000 Deferred libkeyutils.so.1
ELF 7fb74251d000- 7fb74276a000 Deferred libdbus-1.so.3
ELF 7fb74276a000- 7fb7429eb000 Deferred libgmp.so.10
ELF 7fb7429eb000- 7fb742c21000 Deferred libhogweed.so.4
ELF 7fb742c21000- 7fb742e57000 Deferred libnettle.so.6
ELF 7fb742e57000- 7fb74306a000 Deferred libtasn1.so.6
ELF 7fb74306a000- 7fb7433e8000 Deferred libunistring.so.2
ELF 7fb7433e8000- 7fb743605000 Deferred libidn2.so.0
ELF 7fb743605000- 7fb743934000 Deferred libp11-kit.so.0
ELF 7fb743934000- 7fb743b3f000 Deferred libkrb5support.so.0
ELF 7fb743b3f000- 7fb743d43000 Deferred libcom_err.so.2
ELF 7fb743d43000- 7fb743f75000 Deferred libk5crypto.so.3
ELF 7fb743f75000- 7fb74424b000 Deferred libkrb5.so.3
ELF 7fb74424b000- 7fb74445c000 Deferred libavahi-client.so.3
ELF 7fb74445c000- 7fb744668000 Deferred libavahi-common.so.3
ELF 7fb744668000- 7fb7449ce000 Deferred libgnutls.so.30
ELF 7fb7449ce000- 7fb744c19000 Deferred libgssapi_krb5.so.2
ELF 7fb744c19000- 7fb744ea5000 Deferred libcups.so.2
ELF 7fb744ea5000- 7fb7450ab000 Deferred libxfixes.so.3
ELF 7fb7450ab000- 7fb7452b5000 Deferred libxcursor.so.1
ELF 7fb7452b5000- 7fb7454c5000 Deferred libxi.so.6
ELF 7fb7454c5000- 7fb7456c8000 Deferred libxcomposite.so.1
ELF 7fb7456c8000- 7fb7458d3000 Deferred libxrandr.so.2
ELF 7fb7458d3000- 7fb745add000 Deferred libxrender.so.1
ELF 7fb745add000- 7fb745ce3000 Deferred libxxf86vm.so.1
ELF 7fb745ce3000- 7fb745ee6000 Deferred libxinerama.so.1
ELF 7fb745ee6000- 7fb7460ee000 Deferred librt.so.1
ELF 7fb7460ee000- 7fb746303000 Deferred libbsd.so.0
ELF 7fb746303000- 7fb746509000 Deferred libxdmcp.so.6
ELF 7fb746509000- 7fb74670d000 Deferred libxau.so.6
ELF 7fb74670d000- 7fb746935000 Deferred libxcb.so.1
ELF 7fb746935000- 7fb746c6d000 Deferred libx11.so.6
ELF 7fb746c6d000- 7fb746e7f000 Deferred libxext.so.6
ELF 7fb746eaa000- 7fb747149000 Dwarf winex11
-PE 7fb746ec0000- 7fb747149000 \ winex11
ELF 7fb747149000- 7fb74737b000 Deferred libexpat.so.1
ELF 7fb74737b000- 7fb7475c0000 Deferred libfontconfig.so.1
ELF 7fb7475c0000- 7fb7477f2000 Deferred libpng16.so.16
ELF 7fb7477f2000- 7fb747aa6000 Deferred libfreetype.so.6
ELF 7fb747aa6000- 7fb747cd1000 Deferred mpr
-PE 7fb747ab0000- 7fb747cd1000 \ mpr
ELF 7fb747cd1000- 7fb747eee000 Deferred libz.so.1
ELF 7fb747eee000- 7fb748173000 Deferred wininet
-PE 7fb747f00000- 7fb748173000 \ wininet
ELF 7fb748173000- 7fb7483d9000 Deferred oleacc
-PE 7fb748180000- 7fb7483d9000 \ oleacc
ELF 7fb7483d9000- 7fb74868c000 Deferred gdiplus
-PE 7fb7483f0000- 7fb74868c000 \ gdiplus
ELF 7fb74868c000- 7fb7488cd000 Deferred ws2_32
-PE 7fb748690000- 7fb7488cd000 \ ws2_32
ELF 7fb7488cd000- 7fb748bc4000 Deferred comdlg32
-PE 7fb7488d0000- 7fb748bc4000 \ comdlg32
ELF 7fb748bc4000- 7fb748e00000 Deferred oledlg
-PE 7fb748bd0000- 7fb748e00000 \ oledlg
ELF 7fb748e00000- 7fb74917e000 Deferred oleaut32
-PE 7fb748e20000- 7fb74917e000 \ oleaut32
ELF 7fb74917e000- 7fb7493ba000 Deferred uxtheme
-PE 7fb749190000- 7fb7493ba000 \ uxtheme
ELF 7fb7493ba000- 7fb749849000 Deferred shell32
-PE 7fb7493e0000- 7fb749849000 \ shell32
ELF 7fb749849000- 7fb749a90000 Deferred winspool
-PE 7fb749850000- 7fb749a90000 \ winspool
ELF 7fb749a90000- 7fb749ca3000 Deferred msimg32
-PE 7fb749aa0000- 7fb749ca3000 \ msimg32
ELF 7fb749ca3000- 7fb749fd4000 Deferred comctl32
-PE 7fb749cb0000- 7fb749fd4000 \ comctl32
ELF 7fb749fd4000- 7fb74a201000 Deferred msvfw32
-PE 7fb749fe0000- 7fb74a201000 \ msvfw32
ELF 7fb74a201000- 7fb74a44e000 Deferred avifil32
-PE 7fb74a210000- 7fb74a44e000 \ avifil32
ELF 7fb74a44e000- 7fb74a674000 Deferred imm32
-PE 7fb74a460000- 7fb74a674000 \ imm32
ELF 7fb74a674000- 7fb74a8a1000 Deferred msacm32
-PE 7fb74a680000- 7fb74a8a1000 \ msacm32
ELF 7fb74a8a1000- 7fb74ab36000 Deferred rpcrt4
-PE 7fb74a8b0000- 7fb74ab36000 \ rpcrt4
ELF 7fb74ab36000- 7fb74aed7000 Deferred ole32
-PE 7fb74ab60000- 7fb74aed7000 \ ole32
ELF 7fb74aed7000- 7fb74b19a000 Deferred winmm
-PE 7fb74aee0000- 7fb74b19a000 \ winmm
ELF 7fb74b19a000- 7fb74b3b4000 Deferred version
-PE 7fb74b1a0000- 7fb74b3b4000 \ version
ELF 7fb74b3b4000- 7fb74b644000 Deferred advapi32
-PE 7fb74b3d0000- 7fb74b644000 \ advapi32
ELF 7fb74b644000- 7fb74b9bf000 Deferred gdi32
-PE 7fb74b660000- 7fb74b9bf000 \ gdi32
ELF 7fb74b9bf000- 7fb74bdfb000 Dwarf user32
-PE 7fb74b9e0000- 7fb74bdfb000 \ user32
ELF 7fb74bdfb000- 7fb74c088000 Deferred shlwapi
-PE 7fb74be10000- 7fb74c088000 \ shlwapi
ELF 7fb74c188000- 7fb74c3e0000 Deferred liblcms2.so.2
ELF 7fb74c3e0000- 7fb74c602000 Deferred mscms
-PE 7fb74c3f0000- 7fb74c602000 \ mscms
ELF 7fb74c702000- 7fb74c914000 Deferred libnss_files.so.2
ELF 7fb74c914000- 7fb74cb2e000 Deferred libnsl.so.1
ELF 7fb74cb2e000- 7fb74cd3a000 Deferred libnss_nis.so.2
ELF 7fb74cd3a000- 7fb74cf44000 Deferred libnss_compat.so.2
ELF 7fb74d4a4000- 7fb74d6bc000 Deferred libgcc_s.so.1
ELF 7fb74d6bc000- 7fb74da5a000 Deferred libm.so.6
ELF 7fb74da5a000- 7fb74dc5e000 Deferred libdl.so.2
ELF 7fb74dc5e000- 7fb74e04f000 Deferred libc.so.6
ELF 7fb74e04f000- 7fb74e26e000 Deferred libpthread.so.0
ELF 7fb74e613000- 7fb74e83f000 Deferred ld-linux-x86-64.so.2
Threads:
process tid prio (all id:s are in hex)
0000000e services.exe
00000041 0
00000022 0
0000001d 0
00000013 0
00000010 0
0000000f 0
00000011 winedevice.exe
0000001c 0
00000017 0
00000016 0
00000012 0
0000001a plugplay.exe
0000001f 0
0000001e 0
0000001b 0
00000020 winedevice.exe
00000029 0
00000024 0
00000023 0
00000021 0
00000027 explorer.exe
0000002c 0
0000002b 0
0000002a 0
00000028 0
0000003f svchost.exe
00000045 0
00000044 0
00000043 0
00000042 0
00000040 0
00000061 PhotoLine.EXE
00000083 0
00000082 0
00000081 0
00000080 0
0000007f 0
0000007e 0
0000007d 0
0000007c 0
0000007b 0
0000007a 0
00000079 0
00000078 0
00000077 0
00000076 0
00000075 0
00000074 0
00000073 0
00000072 0
00000071 0
00000070 0
0000006f 0
0000006e 0
0000006d 0
00000063 0
00000062 0
0000008f uninstaller.exe
00000099 0
00000090 0
0000009a pl2351.exe
0000009b 0
0000009c pl2351.tmp
0000009d 0
000000aa (D) C:\Program Files\PhotoLine\PhotoLine.EXE
000000ac 0
000000ab 0 <==
System information:
Wine build: wine-3.0 (Ubuntu 3.0-1ubuntu1)
Platform: x86_64
Version: Windows 7
Host system: Linux
Host version: 5.4.0-132-generic
