Ubuntu wsl GVfs metadata is not supported
when ever i open gedit from bash it shows me these warnings
Tepl-WARNING **: 09:44:35.851: GVfs metadata is not supported. Fallback to TeplMetadataManager. Either GVfs is not correctly installed or GVfs metadata are not supported on this platform. In the latter case, you should configure Tepl with --disable-gvfs-metadata.
how to get this solved. help
Welcome.
https://forums.linuxmint.com/viewtopic.php?t=341050
