Don’t worry about that. I see it like a way to learn more about Linux
@Rosika,
Could you please send me the lsusb -t with umts working?
Thanks
@Rosika,
Could you please do these first tests?
Open a terminal window
with umts working write these commands:
sudo grep 001/015 /sys/bus/usb/devices/*/uevent
This is to obtain your USB port form what you gave me:
Bus 001 Device 015: ID 12d1:1001 Huawei Technologies Co., Ltd. E169/E620/E800 HSDPA Modem
The result will be somethig like this:
/sys/bus/usb/devices/yyy-xxx/uevent
with umts working:
write the following command:
sudo echo 'yyy-xxx' > /sys/bus/usb/drivers/usb/unbind
check if umts stops working. If it stops working, write this command:
sudo echo 'yyy-xxx' > /sys/bus/usb/drivers/usb/bind
This is an attempt to just restart the USB port where UMTS is connected
Give the feedback please and indicate the yyy–xxx numbers too
Hi again and tnx,
first of all:
lsusb | grep Huawei
Bus 001 Device 017: ID 12d1:1001 Huawei Technologies Co., Ltd. E169/E620/E800 HSDPA Modem
So the device number changed. Therefore:
lsusb -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/6p, 480M
|__ Port 4: Dev 3, If 0, Class=Vendor Specific Class, Driver=rtsx_usb, 480M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-pci/2p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 3, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 5, If 1, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 2: Dev 5, If 0, Class=Human Interface Device, Driver=usbhid, 12M
|__ Port 3: Dev 6, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 4: Dev 8, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 2: Dev 10, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 3: Dev 12, If 1, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 12, If 2, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 3: Dev 12, If 0, Class=Video, Driver=uvcvideo, 480M
|__ Port 3: Dev 12, If 3, Class=Audio, Driver=snd-usb-audio, 480M
|__ Port 1: Dev 9, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 4: Dev 14, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 4: Dev 14, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
|__ Port 2: Dev 11, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 3: Dev 13, If 0, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 4: Dev 15, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 3: Dev 17, If 4, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 3: Dev 17, If 2, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 3: Dev 17, If 0, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 3: Dev 17, If 3, Class=Mass Storage, Driver=usb-storage, 480M
|__ Port 3: Dev 17, If 1, Class=Vendor Specific Class, Driver=option, 480M
The respective usb-port is 1-1.2.4.4.3 .
I used the command “echo ‘1-1.2.4.4.3’ | sudo tee /sys/bus/usb/drivers/usb/unbind” which I already used in the past. It should have the same effect as the one provided by you.
And indeed umts stopped working.
With “echo ‘1-1.2.4.4.3’ | sudo tee /sys/bus/usb/drivers/usb/bind” I got it working again. So everything behaves as expected.
Greetings
Rosika ![]()
Great.
Know only needs to put the code to run automatically after re(boot)
Late I’ll try to do it
Hi @Rosika,
Sorry for the late answer but I’m tryed to create a solution with systemd but without success
Could you please try these codes?
You will program a cron job to run your code every time your computer (re)boots
Open a terminal and type the follow code:
sudo crontab -e
If it is your first time you use crontab you need to choose the editor. Choose 1 ( nano)
Now, at the bottom of the test, write this:
@reboot /etc/cron.d/umts.sh
Press ctrl+o and Enter to save and ctrl+x to exit nano
With you terminal still open, we will now create your file with undind and bind commands:
sudo nano /etc/cron.d/umts.sh
and write your commands:
#!/bin/sh
echo '1-1.2.4.4.3' | sudo tee /sys/bus/usb/drivers/usb/unbind
echo '1-1.2.4.4.3' | sudo tee /sys/bus/usb/drivers/usb/bind
or my version:
#!/bin/sh
echo '1-1.2.4.4.3' > /sys/bus/usb/drivers/usb/unbind
echo '1-1.2.4.4.3' > /sys/bus/usb/drivers/usb/bind
Save the file ctrl+o and Enter
Exit nano ctrl+x
Turn your file executable:
chmod +x /etc/cron.d/umts.sh
Turn off and on your PC and check if if works
Reboot your PC and check if it works
please give the feedback
Regards,
@Tech_JA:
Hi Jorge,
thank you so much for your help.
I looked through your post and it makes sense.
Yet before I put it into action there´s something I want to be clear of:
The main problem is that in most cases when I (re)boot lsusb doesn´t list the umts-stick at all. So the entries
don´t exist at all and
wouldn´t make any sense. Or do I get this wrong?
Because in the past I already tried
and I got an error or at least it didn´t have any effect at all.
I´m not sure about this but I think the main problem here is that the system doesn´t recognize at boot that the umts-stick is connected. It´s only when I physically disconnect and then connect it again that it does.
Greetings.
Rosika
yes, you’re right.
this code only resets the device
We could try reset the controller again to check if it see the device…
could you try tho reset the second hub?
#!/bin/sh
echo '1-1.2.4' > /sys/bus/usb/drivers/usb/unbind
sleep 4
echo '1-1.2.4' > /sys/bus/usb/drivers/usb/bind
Hi Jorge,
thanks again for yor help.
#!/bin/sh
echo ‘1-1.2.4’ > /sys/bus/usb/drivers/usb/unbind
sleep 4
echo ‘1-1.2.4’ > /sys/bus/usb/drivers/usb/bind
But I´d rather not do that. That might prove counter-productive.
If I unbind ‘1-1.2.4’ I would get rid of access to my keyboard amongst other things. ![]()
I´d say it´s best to leave things as they´re right now.
Even if that means I have to live with some quirks I still have the “solution” of switching off/on my hub and getting the system to recognize the umts-modem that way.
I know that this is an issue to some others as well. And for what it´s worth I´ve still learnt quite a few things with your help.
Thank you again for taking out quite a lot of time trying to solve my issue.
Greetings.
Rosika ![]()
That’s OK, no problem ![]()
@Tech_JA:
Hi Jorge,
I just wanted to thank you for your help.
And, as I already said, I´ve learnt some things during the process.
The crontab-topic is particularly interesting.
And that´s what I like very much in this forum: you can always broaden yor knowledge of Linux.
I´d be glad if I can count on your help in the future as well, if the occasion arises. ![]()
So thanks again and have a good time.
Greetings.
Rosika ![]()
@Rosika,
You can count on me at any time
I don’t know much about Linux, I’m still leaning as I go
Just a note:
unbind a bind your hub you don’t lose your keyboard and other peripherals connecting to hub
I’m tried to find a solution, searching in several sites, forums and even on Huawei’s site ( drivers, firmware…) but didn’t find anything.
I don’t know what else I can do to help you
Thanks a lot. That´s really kind of you.
As far as Linux-learning is concerned it´s the same with me. Although I´ve been using
Lubuntu for quite a while now it seems that there´s still so much to learn.
But it´s awfully interesting I must say.
Well, that´s more than I could hope for.
If I unexpectedly come up with a solution I´ll let you know here. In the meantime I´ll use my hub.
Thanks again and have a nice day.
Rosika ![]()
