How to remove flutter completely?
I guess, you installed the snap package. If so, type in a terminal
sudo snap remove flutter
That should do the trick.
Did it work?
Is your problem solved?
Did you solve it in a different way?
Can we close this topic?
Yes. . . Thankyou.
The pleasure was all mine.
Thank you for responding. This is important for people who search for a solution for the problem and stumble upon this thread.
