How do I fix this, with step-by-step directions.
E: dpkg was interrupted, you must manually run ‘dpkg --configure -a’ to correct the problem.
I’m running Linux mint 20.3 cinnamon version 5.2.7.
Just enter the command on the command line…
sudo dpkg --configure -a
There are two minus signs before configure
typed command in terminal window. What do I do next?
Just repeat whatever you were trying to do when you got the error message
