Using GIMP to Outline Text
I am using GIMP 2.10 and trying to follow “How to Add Border Around Text in Gimp”. Everything works well until I get to page 10 - Select your main image layer. First off, I don’t find any “layers at the right sidebar”.
I have tried selecting various layers - but I cannot get Bucket Fill to work properly. Either the entire line
of text changes color - including the outline, or small portions of the expanded text outline change. Or occasionally the outlined portion and parts of the original text change colors.
What am I doing wrong, or what am I not doing? Please help. John65
I see, you followed
you say:
You should check the bucket tool’s options:
In the screenshot, the option “Fill similar colours” is selected and I guess, this might have happened in your case.
In reality, it should be: “Fill whole selection”. Then, you should be fine.
However, there’s an alternative approach:
Activate the layer with the outline and use the bucket fill tool. Then you should get this:
Everything is filled with the outline colour.
Now do the following: In the layers dialogue, raise the text layer and it will cover the outline.
Raise the activated text layer by clicking the roof symbol:
And get this:
