Hi all,
to those of you making use of “tor”: I have a question/problem as far as “torsocks” is concerned.
My system is: Linux/Lubuntu 20.04.2 LTS, 64 bit and I´m using the IRC client “quassel” on that system.
Per default it came preconfigured with “IRC Networks: irc.ubuntu.com:8001”.
As an example I use the chatroom “#fish” (the one for fish-shell).
Yet I noticed the following entry after the connection is established:
rosika (~quassel@dynamic-[my-ip-address]) hat #fish betreten.
(So basically: “rosika has entered #fish”).
The only thing I wouldn´t be over-enthusiastic about is the fact that my real ip-address is displayed here. So I installed “tor” as an addition and thus have the command “torsocks” available.
In principle tor works as I found out by comparing the output of these two commands:
curl ipv4.icanhazip.com
torsocks curl ipv4.icanhazip.com
They yielded different IPs which is fine.
After establishing that torification in general works I prefixed quassel with torsocks:
The GUI started alright but when trying to establish a connection to e.g. “#fish” the GUI closes and the programme shuts down. Here´s what the terminal says about it:
torsocks quassel
2021-03-16 13:32:49 [Warn ] Missing icon: "inactive-quassel-tray" (using fallback: "inactive-quassel")
2021-03-16 13:32:49 [Warn ] Missing icon: "active-quassel-tray" (using fallback: "active-quassel")
2021-03-16 13:32:49 [Warn ] Missing icon: "message-quassel-tray" (using fallback: "message-quassel")
2021-03-16 13:32:49 [Warn ] SslServer: Certificate file /home/rosika/.config/quassel-irc.org/quasselCert.pem does not exist
2021-03-16 13:32:49 [Warn ] SslServer: Unable to set certificate file
Quassel Core will still work, but cannot provide SSL for client connections.
Please see https://quassel-irc.org/faq/cert to learn how to enable SSL support.
2021-03-16 13:32:49 [Warn ] PostgreSQL driver plugin not available for Qt. Installed drivers: QSQLITE
2021-03-16 13:32:49 [Info ] SQLite storage backend is ready. Schema version: 31
2021-03-16 13:32:49 [Info ] Database authenticator is ready.
2021-03-16 13:32:49 [Info ] Restoring previous core state...
2021-03-16 13:32:50 [Warn ] InputWidget::updateNickSelector(): can't find Identity for Network 1 IdentityId: 0
2021-03-16 13:32:52 [Warn ] Konnte nicht mit Lubuntu IRC (Der entfernte Rechner hat die Verbindung geschlossen) verbinden
2021-03-16 13:32:53 [Info ] Caught signal 11
Surely I´m doing something wrong here. Can anybody help me how to proceed now, please?
Thanks a lot in advance.
Many greetings.
Rosika
