I have an SSD drive can I use it instead of the USB? I don’t have the USB. If I can use the SDD then I won’t have to buy the USB. I am referring to the instructions here How to Install Linux Mint 20 From USB [Easiest Way] that says for one of the requirements is an USB of at least 4 GB or DVD, and then using etcher to make it live. I don’t intent to use the SSD as a portable media, just one time to get things going.I will then remove the ISO file and use it for something else. I have read elsewhere that you would have to follow through certain instructions to get the SSD to be live; that is to make partitions, etc. using the sudo command. I thought I would ask here since the instructions are provided for this specific topic.
It will work if you consequently pretend the SSD is a thumb drive.
What he said - just make sure you pick the SSD as the destination from whatever software (etcher?) you’re using to flash the image…
Hi there.
As our experts stated, it’s releatively easy possible to use a (external) SSD for installing.
If you will, you can give Ventoy a try.
With it you just have to prepare the drive, and then it’s just copying the desired ISO(s) onto.
I use it mostly as a convenient way to carry around (and show off) some of the popular distros, just in case someone wants to see, or has a problem that needs to be fixed.
I did installations with the Ventoy drive (which is an external USB-SSD), it runs just as if you used a DVD or regular thumbdrive.
Did I miss something? Can’t Tux buy a dozen USB’s for the price of one SSD? Around here they’re almost as disposable as DVD’s.
Who exactly are you referring to?
yeah… I tend to agree… on my desk I’ve got literally 10’s of USB thumb drives that could take any modern distro (4 GB to 256 GB)… they so cheap and ubiquitous - in real terms (today’s money vs antiquity’s) they’re vastly cheaper than floppy disks and way more convenient than optical media - and they’re more reliable than floppy disks for sure…
Tux:
Couldn’t figure out why he would want to use an SSD instead of a USB. Just install the SSD in his machine and use a simple USB for temporary installation experiments. The devices are in most ways totally different.
