@ihasama ,
Well done,
It is a hardware issue after all.
It may not be an easy job checking sata cables and pcie cards in a laptop.
I think the best option is to start finding a ānewā laptop. I plan to buy a used one. Many companies here rent their laptops and after 2-3 years they are āoldā and then they rent new ones.. I can get a decent business laptop (like Elitebook or Thinkpad) for 500-600ā¬. They usually have i5/10th gen and 16gb RAM. You get warranty for the laptop also.
Good choice⦠assuming you must have a laptop.
I prefer desktops, but I do not need to be mobile.
My i5 desktop was a refurbished one.
Yes. I use it for my work at home and at work. I am tempted to buy a MAC with M1 and put Linux to it but they are still pricey. It is small, no fan and the battery lasts for the whole day.
Could be a problem with compatability, the m1 was not around that long, not tried one myself with linux so just a question.
Hi Paul, I have Pinebook Pro which has arm64 architecture processor like the M1. The bootloader part is different, you need a pre-bootloader before grub (like m1n1,tow-boot,u-boot) and of course the OS needs to be ARM64, not x86_64. But Iāve installed Gentoo to the Pinebook Pro and all needed apps works. Thereās special kernel for M1 chip (Asahi) and great instructions how to install on Gentoo wiki. But this is off topic here!
Thanks for the extra info, thought it was unique to the mac
Thereās also Snapdragon laptops with ARM64.
My next attempt at an rsync recovery
Reinstall Peppermint
set intel_iomme=off in /etc/default/grub
apt update-upgrade
install firefox-esr, rsync -
mkdir /mnt/backup
mount /dev/sdd3 /mnt/backup
rsync -avxHAXS
āexclude={/dev/,/proc/,/sys/,/run/,/mnt/,/media/, /tmp/*}
/ /mnt/backup -
check
sent 5,597,058,547 bytes received 8,623,031 bytes 53,134,422.54 bytes/sec
total size is 5,988,749,451 speedup is 1.07
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1338) [sender=3.2.7]
# ls /mnt/backup
bin dev home lib lost+found mnt proc run srv tmp var
boot etc initrd.img lib64 media opt root sbin sys usr vmlinuz
It looks OK.
- Try a recovery to an non-running Peppermint
One file called fosstry2 has been edited since the backup.
I booted MX and did the following within MX
Identify /dev/sdi3 as the backup made in 2. above
Identify /dev/sdh7 as the Peppermint partiton to be recovered to.
mount /dev/sdi3 /mnt/source
mount /dsv/sdh7 /mnt/dest
rsync -avxHAXS --exclude={/dev/*,/proc/*,/sys/*,/run/*,/mnt/*,/media/*,/tmp/*,/etc/mtab} /mnt/source/ /mnt/dest
That recovers on top of the existing Peppermint ⦠I did not erase it.
I then booted Peppermint⦠it booted OK, and I was able to check files.
It set dates of all files in my /home/nevj dir to 2 days ago,
and it changed the modified file to its version 2 days ago, but it also changed its
ownership to root⦠I must hav originally made the file as root..
It also recovered a number of .mozilla files, and some thing in /usr/lib/rc/cache.
It looks to me like the recovery was successful, except for the file ownership issue.
So I mount the backup copy and check⦠surprise !!! the file fosstry2 is not there.
So rsync must have deleted it ???
We do not have it quite right yet⦠wipe it all and start again⦠--delete is a tricky option
When will I learn to mount the backup read only
Update:
The man page says
--delete
This tells rsync to delete extraneous files from the receiving side (ones that
aren't on the sending side), but only for the directories that are being
synchronized. You must have asked rsync to send the whole directory (e.g.
lqdirrq or lqdir/rq) without using a wildcard for the directory's contents (e.g.
lqdir/*rq) since the wildcard is expanded by the shell and rsync thus gets a
request to transfer individual files, not the files' parent directory. Files that are
excluded from the transfer are also excluded from being deleted unless you
use the --delete-excluded option or mark the rules as only matching on the
sending side (see the include/exclude modifiers in the FILTER RULES section).
Prior to rsync 2.6.7, this option would have no effect unless --recursive
was enabled. Beginning with 2.6.7, deletions will also occur when --dirs (-d) is enabled, but only for directories whose contents are being copied.
This option can be dangerous if used incorrectly! It is a very good idea to
first try a run using the --dry-run option (-n) to see what files are going to be deleted.
I dont see anything about deleting files on the <source> ???
It seems to have done the recovery properly, but destroyed the backup in the process. ??
I am confused⦠I have to do it all again carefully and double check.
I think maybe your laptop may be like my J1900 Acer Mini, anything over kernel 6.12.54 will not boot!!! I have locked it down, and only use ā emerge -a -uD @system ā to keep my core apps updated!!!
I use this machine and Gentoo equery to get package deps for LFS!!! I could very much so live without it, but it is still running just fine!!!
I use 6.12.63 (binary) at the moment:
āā[pete@gentoo]ā[~]
āāāā¼ uname -a
Linux gentoo 6.12.63-gentoo-dist #1 SMP PREEMPT_DYNAMIC Thu Dec 18 19:15:56 -00 2025 x86_64 Intel(R) Core(TM) i5-8265U CPU @ 1.60GHz GenuineIntel GNU/Linux
I know you already are aware of the masking but in case someone else meet this kind of problem with Gentoo hereās a wiki page how to prevent portage to update a package you donāt want it to update:
I have use package.mask and have locked down all avenues for kernel updates!!!
My Gentoo does not compile a kernel unless I tell it to⦠Are you guys using binaries?
Yes, I use the gentoo-kernel-bin
Are you guys using binaries? Yes, but masking keeps from pulling in the kernel updates, and you just get a notification from portage, but this does not keep me from using ā emerge -a -uD ā to keep Gentoo updated!! If Gentoo offered a LTS kernel, I might consider it!!!
What happens if you simply copy an initrd and a vmlinuz and /lib/modules into a Gentoo filesystem.?
I think that is all that is involved in installing a kernel?
Portage might react, but you can put it in a straightjacket.
I have no idea, but I have my doubts it would boot!!!
I have two M1 MacBook Pros - one is workāsā¦
I canāt see any reason whatsoever to favour Linux over MacOS - MacOS is UNIX and it comes with a shell (ZSH by default - the one I use nearly everywhere)ā¦
My personal M1 was reasonably priced - probably cheaper than a Dell XPS - bought it in 2021⦠I kinda wish Iād got an M1 āAirā instead now - was $300 (AUD) cheaperā¦
All the Linux stuff (UNIX-ish) that I use - in a shell, is available on MacOS via brew / homebrew (e.g. ffmpeg) :
āāx@methone.local ~
ā°ā⤠uname -a
Darwin methone.local 24.6.0 Darwin Kernel Version 24.6.0: Mon Jul 14 11:30:34 PDT 2025; root:xnu-11417.140.69~1/RELEASE_ARM64_T8103 arm64
āāx@methone.local ~
ā°ā⤠history |grep brew|grep install|grep ffmpeg|grep -v grep
3256 brew install ffmpeg
3567 brew install ffmpeg
4537 brew install ffmpeg streamlink
Itās pretty much FreeBSD and itās mostly POSIX compliant.
Even 5 years later - Linux on Apple Silicon is not yet 100% ready⦠I think Linus Torvalds was running one - with Asahi - he was using an M1 to build the kernel⦠But I think his daily driver is still an AMD Threadripper desktop machine (see Linus Tech Tips where he works with Linus Torvalds to build a Threadripper desktop).
As per above - I donāt see the point really⦠The only reason I could see for installing Linux on a Mac, would be if it was Intel and there were no more MacOS updates for it⦠Lotsa people run Linux on Intel CPU Macs⦠Me? Iām agnostic - happy to use bash/zsh shell on anything remotely āUNIX-likeā - i.e. Linux or MacOSā¦
The M1 has been around nearly 5 years now!
I donāt know if Apple even sell M1 anymore - everything is probably M2, 3 or 4 now⦠Maybe a few iPad models still using the M1?
The only problem would be if Gentoo needed certain kernel parameters set.
You might get away with it.
Do you have a spare Gentoo lying around that you could try it on?
Not really!!!
