Does anyone know how to install videoinfo. When I run this command:
videoinfo: command not found
Any ideas?
Cheers
Any ideas?
Cheers
All the results I get for videoinfo are related to GRUB2.
As far as i know there is no such thing as videoinfo on the linux platform. What do you want to accomplish with the software you’re looking for?
I was following instruction here on how to change Grub resolution.
Ah, Akito was right. videoinfo is a command that can be run in the Grub command console, it’s not available as ‘regular’ software that can be installed from within Linux.
Ok, would you know how to install? Not in the default repo
What’s your issue? Only the GRUB resolution or what’s the problem with GRUB?
Not a major issue, more of a pet hate
On boot up I get text shown, however just before the GUI plymouth screen displays, the text becomes massive on the screen, as though the resolution drops. I don’t know if the GRUB resolution has anything to do with it, but I wanted to check if the resolution I set was available. In a tutorial, it said use videoinfo to check available screen resolutions. However I set the resolution to my desktop resolution in the /etc/default/grub file. The solution I was following was found here
