TypeHrishi
(Hrishikesh Kelkar)
1 July 2023 16:47
1
Hi!
I have a fingers 108- hi res webcam which war working fine till the last month.
I opened my Pop os 22.04 after a month and its not detecting the webcam and the mic
Tried various solutions from web but non worked.
This is what it looks in settings
Please help as soon as possible!
Thanks in advance!
abhishek
(Abhishek Prakash)
2 July 2023 04:53
2
From the Terminal, run
alsamixer
In here, press F6 to select sound card and make sure that you see and select a sound card:
TypeHrishi
(Hrishikesh Kelkar)
2 July 2023 05:58
3
HI!
First of all, thanks for the reply.
I saw 3 options:
default, intel and nvidia
Tried all three but none of them captured the mic.
Any other solutions?
Thanks,
Hrishikesh.
TypeHrishi
(Hrishikesh Kelkar)
2 July 2023 06:09
4
I just tried the solution u gave and i noticed something:
Here u can see the card and chip is shown as pulseaudio while it should be pipewire right?
Maybe it happened becuz I tried various solutions from internet yesterday, or maybe because of any other reason, I dont know!!
Any help would be appreciated and respected!
Thanks,
Hrishikesh.
abhishek
(Abhishek Prakash)
2 July 2023 06:33
5
That could be the reason because if I remember correctly, Pop OS switched to Pipewire with version 22.04.
Try this and see if it works.
Reinstall Pipewire:
sudo apt reinstall pipewire pipewire-pulse
And then enable it:
systemctl --user --now enable pipewire pipewire-pulse
Now see if it works or not. You should not need it but still, reboot if it is not working immediately.
TypeHrishi
(Hrishikesh Kelkar)
2 July 2023 06:45
6
Tried it , no luck.
Thanks for quick response btw.
abhishek
(Abhishek Prakash)
2 July 2023 06:56
7
Too bad.
Does it at least show Pipewire in Alsamixer now?
Perhaps try changing the sound card?
System76 has a dedicated page… but please make Timeshift backup or something like that so that you can restore things later (if you mess it up further).
I have to go out now (Sunday is for family). I will check the discussion again in the evening. Good luck.
TypeHrishi
(Hrishikesh Kelkar)
5 July 2023 16:07
8
Okay so I identified that the prob is with the webcam(hardware).
Sorry for bothering and disturbing!
Thanks for the quick responses though!
